  3. SKlLL to Offsets lines and arcs by a specified distance...
  • State Verified Answer
  • Replies 11
  • Subscribers 20
  • Views 8264
SKlLL to Offsets lines and arcs by a specified distance,
Xiaome8
Xiaome8 over 1 year ago
Hi Bro,
would you help to provide the skill which can offsets lines and arcs by a specified distance ,like the following picture show, (the original command offset copy is not good for any angle copy , only support X or Y direction offset copy)
thanks in advanced!
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago in reply to Xiaome8 +1 verified
    Hi Xiaome8, you can refer this code. axlCmdRegister ( "offset_line" `offset_line ) ( defun offset_line ( ) axlVisibleLayer ( "anti etch/all" , t ) axlClearSelSet () axlSetFindFilter ( ? enabled…
  • Hoangkhoipcb
    Hi Xiaome8, Here your the code: ;+++++++++++++++++++++++++++++++++++++++++++++++++++++++++ axlCmdRegister("offset_line" `offset_line) offset_value_s = "" (defun offset_line () offset_value = axlUIPrompt…
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to Xiaome8
    Hi xiaome8,
    Usages:
    Enter offset value
    Pick side offset
    HoangKhoi.
    offset_value = axlUIPrompt( "Enter offset value" "250.0" )
    if(offset_value != nil && atof(offset_value) > 0.0 then
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall CLINES NAMEFORM) ?onButtons '(noall ALL))
    axlSingleSelectPoint()
    cline = car(axlGetSelSet())
    axlClearSelSet()
    if( cline != nil then
    pick_airgap = axlEnterPoint()
    if(pick_airgap != nil then
    _airgap = axlAirGap(cline pick_airgap nil 'enhanced)
    airgap = axlAirGap(cline pick_airgap nil 'anyLayer)
    if(_airgap != nil && _airgap->airgap > 0.0 then
    ol = axlGeoCircleLineInt2(_airgap->location1 _airgap->location2 _airgap->location1 atof(offset_value))
    dis1 = axlDistance(_airgap->location2 car(ol))
    dis2 = axlDistance(_airgap->location2 cadr(ol))
    pick_airgap = car(ol)
    if(dis2 < dis1 then
    pick_airgap = cadr(ol)
    segs = cline->segments
    st_end_list = segs~>startEnd
    st_seg = car(segs)
    first_seg_point = car(st_seg->startEnd)
    tmp = setof(e st_end_list e != st_seg->startEnd && member(first_seg_point e) != nil)
    if(tmp != nil then first_seg_point = cadr(st_seg->startEnd))
    last_seg = lastelem(segs)
    last_seg_point = car(last_seg->startEnd)
    tmp = setof(e st_end_list e != last_seg->startEnd && member(last_seg_point e) != nil)
    if(tmp != nil then last_seg_point = cadr(last_seg->startEnd))
    cline_poly = axlPolyFromDB(cline ?endCapType 'ROUND )
    if(length(cline_poly)>1 then
    cline_poly = car(axlPolyOperation(car(cline_poly) cdr(cline_poly) 'OR))
    exp_poly = car(axlPolyExpand(cline_poly atof(offset_value) + car(cline->segments)->width*0.5 'NONE))
    axlClearSelSet()
    axlAddSelectPoly(exp_poly t)
    cline_displays = axlGetSelSet()
    axlDBAddProp(cline_displays list( "FIXED" t))
    axlDBRefreshId(nil)
    shape = car(axlDBCreateShape(exp_poly t "anti etch/all"))
    rpath = axlDB2Path(shape)
    new_cline = car(axlDBCreatePath(rpath cline->layer nil ) )
    seg_width = car(cline->segments)->width
    axlChangeWidth(car(new_cline), car(cline->segments)->width )
    axlDeleteObject(shape)
    new_cline = car(new_cline)
    foreach(seg new_cline->segments
    if(seg->xy != nil then
    if(axlDistance(seg->xy first_seg_point) <= seg_width || axlDistance(seg->xy last_seg_point)<= seg_width then
    axlDeleteObject(seg)
    axlClearSelSet()
    clines = axlGetSelSet()
    foreach(item clines
    cline_poly = axlPolyFromDB(item ?endCapType 'NONE )
    exp_poly = car(axlPolyExpand(cline_poly seg_width 'NONE))
    if(!axlGeoPointInShape(pick_airgap exp_poly nil) then
    if(axlDBIsFixed(item) == nil then
    axlDeleteObject(item)
    axlDBDeleteProp(cline_displays list( "FIXED"))
    axlShell("offset_line")
  • Xiaome8
    0 Xiaome8 over 1 year ago in reply to Hoangkhoipcb
    Hi HoangKhoi ,
    The code has improve as the pattern I mention above, but it is a little strange that the cline width is sometime is 0um width(wrong), sometimes use the one default(right value)
    and the axlUIPrompt dialog box (250 spacing)is always on ,so every time need to put the offset value to replace 250,
    so can you help optimize the offset value can keep the value which user give? thanks again~
  • Hoangkhoipcb
    +1 Hoangkhoipcb over 1 year ago in reply to Xiaome8
    Hi Xiaome8,
    Here your the code:
    offset_value_s = ""
    offset_value = axlUIPrompt( "Enter offset value:" offset_value_s)
    offset_value_s = offset_value
    axlClearSelSet()
    axlClearSelSet()
    if(dis2 < dis1 then
    st_seg = car(segs)
    axlClearSelSet()
    axlDBRefreshId(nil)
    axlClearSelSet()
    foreach(item clines
  • Xiaome8
    Hi HoangKhoi ,
    This one is good ! thanks!
     Niubility!
  • Xiaome8
    Hi HoangKhoi,
    Good day!
    For the offset cline skill code is perfect, I have a new idea for further development this code to replace the Resize/Respace Diff Pairs command (the cadence command is not good for arc type  and non-45 degree diff-pair adjustment)
    (To get the code more simple,I thinks no need to update the constrain DRC or change cline width . for they can use another command), just need to offset 2 P/N clines to the space we want.
    so if you have time ,would you help to study for it?as far as I know currently ,there is few skill for diff-pair adjustment.
