  3. Cadence AI for Skill code?
  • State Verified Answer
  • Replies 8
  • Answers 2
  • Subscribers 23
  • Views 8125
ltoohey
ltoohey over 1 year ago
Does anyone know Cadence has or is working on any AI tools for writing Skill code?
  • Ejlersen
    Ejlersen 11 months ago in reply to KR202512038838 +2
    Using Copilot it is possible to create an agent that uses the SKILL documentation (algroskill.pdf, skilide.pdf and sklangref.pdf) and start using this for autogeneration of SKILL code provided you create…
  • Elecguy
    Elecguy 8 months ago in reply to ltoohey +2 suggested
    I've used the Teams Copilot for it ... it's not 100% accurate but it's a good start
  • JuanCR
    JuanCR over 1 year ago +1 verified
    Hi Itoohey As of now there is not an AI tool for writing SKILL code. If this is developed in the future it will be announced via the official channels.
  • Ejlersen
    0 Ejlersen 11 months ago in reply to KR202512038838
    Using Copilot it is possible to create an agent that uses the SKILL documentation (algroskill.pdf, skilide.pdf and sklangref.pdf) and start using this for autogeneration of SKILL code provided you create a good prompt.
    Notice that it will be an iterative process where you would need to know about SKILL and help correct it through additional prompts.
    I've successfully created code using this approach, but without knowledge about how SKILL works this will not work from what I've seen so far, but it really decreases the time it takes to create the overall code.
    So if you're willing to help it correct mistakes, then I would recommend having a go for it.
    As a side note I've seen that I have to direct it to use correct axl functions at times and also to point to correct -> pointers
    /Ole
    • Vote Up +2 Vote Down
  • ltoohey
    0 ltoohey 8 months ago in reply to Ejlersen
    Seems like these AI tools are getting better at churning out SKILL code.
    I am able to get working SKILL programs over 1000 lines long now.
    As mentioned above this is an iterative process and sometimes SKILL functions are hallucinated and have to be corrected.
    It also helps if you can feed the AI tools working SKILL programs as reference.
    I sure wish Cadence would off some tools for this though... :)
  • Elecguy
    0 Elecguy 8 months ago in reply to ltoohey
