  2. Allegro X Scripting - TCL
  3. SysCap - "Swap" Net Name"
  • State Verified Answer
  • Replies 19
  • Subscribers 16
  • Views 19027
JohnFr38
JohnFr38 over 3 years ago
Hi Everyone,
I'm having a problem using SysCapture. I would like to swap "net name" of a FPGA
On VHD designer -> Texte/swap
On SysCap -> Swap PIN
But the function modifies the PIN name and not the associated NET.
  • CadAP
    CadAP over 3 years ago in reply to JohnFr38 +4 verified
    Thanks for reply JohnFr38 #I have made little changes to the code. Please copy the below tcl code. You have to select pins of components whose nets need to be interchanged. #Please follow below steps…
  • CadAP
    CadAP over 3 years ago in reply to JohnFr38 +2 verified
    #After sourcing the below tcl code "CustomMenu" will be added and active till the System Capture is open. If you closed the system capture then you need to source the tcl file again. See the below attached…
  • srish09
    srish09 over 3 years ago +1
    Hello John, Are you swapping the pins in pcb editor and then importing the layout into System Capture? As per the flow, pins within the same pin group can be swapped in pcb editor. These changes can…
  • CadAP
    +1 CadAP over 3 years ago in reply to JohnFr38
    #Please follow below steps:
    1.Copy the below code in a notepad and save with .tcl extension.
    2. Please select the two Pins of component whose nets need to be interchanged. See the below attached screenshot
    3.Source the tcl code in System Capture command window.
    Please take a backup of your project and then run the tcl.
    Hope this helps!
    proc swapNetsName {} {
    set pageId [sch::dbGetActivePage]
    set pageSpath [sch::dbGetActivePageSpath]
    set selectedItems [sch::dbGetSelectedItems $pageId]
    if { [llength $selectedItems] > 0 } {
    foreach item $selectedItems {
    set itemId [sch::dbGetConnectedItems $item]
    # puts $itemId
    set itemType [sch::dbGetType $itemId]
    # puts $itemType
    if {$itemType eq $sch::DBTRoute} {
    set name [sch::dbGetItemName $itemId]
    set netpos [sch::dbGetPos $item]
    set netXY [ sch::dbConvertToUserUnits $netpos]
    lappend netlist $name
    lappend netXYPos $netXY
    # return $netlist
    # return $netXYPos
    if {[llength $netlist] == 2} {
    # puts "$netlist"
    # puts "$netXYPos"
    set net0 [lindex $netlist 0]
    # puts $net0
    set net1 [lindex $netlist 1]
    # puts $net1
    set net0Xpos [lindex [lindex $netXYPos 0] 0]
    # puts $net0Xpos
    set net0Ypos [lindex [ lindex $netXYPos 0] 1]
    # puts $net0Ypos
    set net1Xpos [lindex [lindex $netXYPos 1 ] 0]
    # puts $net1Xpos
    set net1Ypos [lindex [lindex $netXYPos 1] 1]
    # puts $net1Ypos
    renameSignal -pg $pageSpath -net [list $net0Xpos $net0Ypos $net0 $net1]
    renameSignal -pg $pageSpath -net [list $net1Xpos $net1Ypos $net1 $net0]
    puts "Successfully interchange selected instances of $net0 with $net1"
    selectObject none
    if { [llength $selectedItems] <= 1 } {
    puts "Net Interchange tcl Does Not Run For Single Net. Please Select Two Pins whose nets need to be interchanged "
    if {[llength $selectedItems] > 2} {
    puts "More than two Pins are selected, Please select two Pins"}
    } else {puts "No Object Is Selected On The Schematic!"}
    swapNetsName
    • Vote Up +4 Vote Down
  • JohnFr38
    0 JohnFr38 over 3 years ago in reply to CadAP
    Thanks a lot, the script works great! And exactly as I want it to!
    Can I turn the script into a button? Or do I have to run it every time from the command line?
  • CadAP
    #After sourcing the below tcl code "CustomMenu" will be added and active till the System Capture is open. If you closed the system capture then you need to source the tcl file again. See the below attached screenshot.
    # For AutoLoading tcl in System Capture you can follow the below link:
    support.cadence.com/.../ArticleAttachmentPortal
    proc callMenu {} {
    set menu {CustomMenu}
    addMenuToMenuBar $menu {} 1 {} sch
    addActionToMenu $menu "Swap_Net" swapNetsName {} {} {} sch
    # puts $itemId
    # puts $itemType
    # return $netlist
    # return $netXYPos
    # puts "$netlist"
    # puts "$netXYPos"
    # puts $net0
    # puts $net1
    # puts $net0Xpos
    # puts $net0Ypos
    # puts $net1Xpos
    # puts $net1Ypos
    selectObject none
    callMenu
    • Vote Up +2 Vote Down
  • JohnFr38
    It's the best solution! Thank you so much!
    This solution is 100% functional and even allows you to add a keyboard shortcut!
    I had read another guide that asked you to put scripts in "canvas/resources/sda" Now I understand where the mistake was
    Thanks again
  • MZ20250602835
    0 MZ20250602835 10 months ago in reply to CadAP
    Dear CadAP,
    may i ask you if i run On SysCap -> Swap PIN. How could i swap the pin number and pin name together? Currently only Pin Number swapped without Pin Name swapped together.
    Many thanks.
    Moyan
