  2. Allegro X Scripting - TCL
  3. Exporting variants.lst through tcl or automation
  • State Verified Answer
  • Replies 9
  • Subscribers 12
  • Views 4449
PatEscher
PatEscher over 1 year ago
is there any way to export the variants.lst file through either tcl code, a command or any other utility, so that we can automate this process?
as of today, this has to be done manually through the Part Manager UI, and this is quite error prone as the users are missing this a lot and the variants.lst is either then not available or not up to date in Allegro
Patrick
  • Jeet
    0 Jeet over 1 year ago
    Try using following steps:
    1. Enable Journaling and Display Commands from Extended Preferences > Command Shell.
    2. Now, select and right click on the design file in the project manager and open Part Manager.
    3. Copy MenuCommand number from the command window and replace it in the below code in place of 14604 >
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lDesign [$lSession GetActiveDesign]
    if { $lDesign != $lNullObj} {
    MenuCommand "14604"
    Menu "Tools::Export Variant List"
    return
    4. Run the TCL script in the command window and Hit Export it will create variants.lst file.
    Hope this helps!
  • PatEscher
    0 PatEscher over 1 year ago in reply to Jeet
    Hello Vishwajeet,
    unfortunately this brings up the UI which requires a user input.
    I am looking for a full automation, so without User Input.
    is there a possibility to control the UI also through an xml file, like when switching to the variant view (even if controlling the UI is not really a good practice :)
  • CadAP
    0 CadAP over 1 year ago in reply to PatEscher
    Hi Pat,
    Please use the below tcl code. It will generate one file with name VariantBom.txt active directory (pwd command used to check the active directory).
    Generate file contains the similar information as in variant.lst file (like variant name , All parts form group and Subgroup(if part of a variant)).
    proc dumpVarinatsubBoms {BomSubgGroupNameList} {
    set lNullObj "NULL"
    set fileReport [open "VariantBom.txt" a+]
    set lDesign [GetActivePMDesign]
    set lCISDesign [CPartMgmt_GetCisDesign $lDesign]
    set variantBomCNewBOm [$lCISDesign GetBOMVariantContainer]
    set VariantBomCount [$variantBomCNewBOm GetBomCount]
    # $lCISDesign GetGroupsContainer
    set CVariants [$lCISDesign GetGroupsContainer]
    # puts [$CVariants GetGroupCount]
    set lAllGroupCSArray [CISTclHelper_sMakeCStringArray]
    $CVariants GetAllGroups $lAllGroupCSArray
    set lGroupCount [$CVariants GetGroupCount]
    set lGetSubGroupCString [DboTclHelper_sMakeCString]
    # puts "$lAllGroupCSArray"
    # puts "$lGroupCount"
    set lAllCommonParts [CISTclHelper_sMakeCUIntArray]
    # puts $lPartsCount
    $lCISDesign GetCommonParts $lAllCommonParts
    set lAllCommonPartsCount [CISTclHelper_sGetCUIntArraySize $lAllCommonParts]
    for {set z 0} {$z < $lGroupCount} {incr z} {
    set lGroupNameCString [CISTclHelper_sGetCString $lAllGroupCSArray $z]
    set lAllSubGroupCSArray [CISTclHelper_sMakeCStringArray]
    # puts $lGroupNameCString
    set lGroupName [DboTclHelper_sGetConstCharPtr $lGroupNameCString]
    # puts $lGroupName
    set lSubGroupCount [$CVariants GetSubGroupCount $lGroupNameCString]
    # puts $lSubGroupCount
    if {$lSubGroupCount > 0} {
    set subgrouplist {}
    set lGetSubGroup [$CVariants GetAllSubGroup $lGroupNameCString $lAllSubGroupCSArray ]
    # set lSubGroupCount [$CVariants GetSubGroupCount $lGroupNameCString]
    for {set k 0} {$k <$lSubGroupCount} {incr k} {
    set lSubGroupNameCString [$CVariants GetSubGroupByIndex $lGroupNameCString $k]
    set lSubGroupName1 [DboTclHelper_sGetConstCharPtr $lSubGroupNameCString]
    lappend subgrouplist $lGroupName\_$lSubGroupName1
    if {$lSubGroupCount == 0} {
    set subgrouplist {}
    # puts [$variantBomCNewBOm IsGroupInBom $lGroupNameCString]
    if {[$variantBomCNewBOm IsGroupInBom $lGroupNameCString] == 1 && [lsearch $BomSubgGroupNameList $lGroupName ] > -1} {
    set lAllGroupParts [CISTclHelper_sMakeCUIntArray]
    $CVariants GetPartsFromGroup $lGroupNameCString $lAllGroupParts
    set lPartsCount [CISTclHelper_sGetCUIntArraySize $lAllGroupParts]
    # puts $lPartsCount
    # puts "+++++ VariantBomName:$VarinatName +++++++++"
    # puts "==========Group:=$lGroupName =========="
    puts $fileReport "==========Group:=$lGroupName =========="
    for {set y 0} {$y < $lPartsCount} {incr y} {
    set partNumber [DboTclHelper_sMakeCString "Part_Number"]
    set lPartId [CISTclHelper_sGetUInt $lAllGroupParts $y]
    # puts $lPartId
    if {$lPartId != 0 } {
    # set lSubGroupName [DboTclHelper_sMakeCString ""]
    set lUINTPartId [CISTclHelper_sGetUINTFromInt $lPartId]
    set lCISInstOcc [$lCISDesign GetPartOccForID $lUINTPartId]
    set lCispatInst [$lCISInstOcc GetOwningCISPartInst]
    set lRefDes [$lCISInstOcc GetPartRefDes]
    set lRefDes [$lRefDes GetRefDes]
    set lRefDes [DboTclHelper_sMakeCString $lRefDes]
    set lRefDesStr [DboTclHelper_sGetConstCharPtr $lRefDes]
    # puts $lRefDesStr
    puts $fileReport $lRefDesStr
    foreach subgrp $subgrouplist {
    # puts $subgrp
    set lGroupNameCString1 [DboTclHelper_sMakeCString $subgrp]
    set lStringindex [string last "_" $subgrp]
    set lSubGroupName [string range $subgrp [expr {$lStringindex + 1}] end]
    set lSubGroupNameCS [DboTclHelper_sMakeCString $lSubGroupName]
    # puts $lSubGroupName
    # puts [$variantBomCNewBOm IsGroupInBom $BomSubgGroupName]
    if {[$variantBomCNewBOm IsGroupInBom $lGroupNameCString1] == 1 && [lsearch $BomSubgGroupNameList $subgrp ] > -1 } {
    # set lNullObj "NULL"
    set lSubGroupPart [CISTclHelper_sMakeCUIntArray]
    # set lSubGroupName [$CVariants GetSubGroupByIndex $lGroupNameCString $x]
    $CVariants GetPartsFromSubGroup $lGroupNameCString $lSubGroupNameCS $lSubGroupPart
    set lSubPartsCount [CISTclHelper_sGetCUIntArraySize $lSubGroupPart]
    # puts "==========SubGroup:= $subgrp ========="
    puts $fileReport "==========SubGroup:= $subgrp ========="
    for {set i 0} {$i < $lSubPartsCount} {incr i} {
    # set partNumber [DboTclHelper_sMakeCString "Part_Number"]
    set lPartId [CISTclHelper_sGetUInt $lSubGroupPart $i]
    # puts $lPartId
    if { $lCISInstOcc != $lNullObj } {
    # puts $lRefDesStr
    # puts $subgroup
    # delete_CISInstOccurrence $lCISInstOcc
    # puts "==============BASE PART/COMMON_PART=============="
    puts $fileReport "==============BASE PART/COMMON_PART=============="
    for {set i 0} {$i<$lAllCommonPartsCount} {incr i} {
    set lPartId1 [CISTclHelper_sGetUInt $lAllCommonParts $i]
    # puts $lPartId1
    if {$lPartId1 != 0 } {
    set lUINTPartId1 [CISTclHelper_sGetUINTFromInt $lPartId1]
    set lCISInstOcc1 [$lCISDesign GetPartOccForID $lUINTPartId1]
    set lRefDes [$lCISInstOcc1 GetPartRefDes]
    # puts $lRefDes
    # puts $lRefDesStr
    close $fileReport
    set lNullObj "NULL"
    set lVarinatBomCSS [CISTclHelper_sMakeCSStringArray]
    # set lVarinatBomCS [CISTclHelper_sMakeCStringArray]
    set lBomList [$variantBomCNewBOm GetBomVariants $lVarinatBomCSS]
    # set lBomReport [open "VariantBom.txt" a+]
    if {[file exists "VariantBom.txt"] == 1} {
    set foo [open "VariantBom.txt" w+]
    set lCSSArraySize [CISTclHelper_sGetCStringArraySize $lVarinatBomCSS]
    set VbomList {}
    for {set i 0} {$i < $lCSSArraySize} {incr i} {
    set VbomList {}
    set bomlist {}
    set lBomDataCS [CISTclHelper_sGetCString $lVarinatBomCSS $i]
    # set VbomList [lreplace $VbomList 0 end "" ]
    # set bomList {}
    # puts "+++++++++ BOM_Variant_Name:== [DboTclHelper_sGetConstCharPtr $lBomDataCS] ++++++++++"
    puts $lBomReport "+++++++++ BOM_Variant_Name:== [DboTclHelper_sGetConstCharPtr $lBomDataCS] ++++++++++"
    set lBomData [DboTclHelper_sGetConstCharPtr $lBomDataCS]
    $variantBomCNewBOm GetBomGroups $lBomDataCS $lVarinatBomCS
    set lArraySize [CISTclHelper_sGetCStringArraySize $lVarinatBomCS]
    for {set z 0} {$z < $lArraySize} {incr z} {
    set lVbomData {}
    set lVbomData [CISTclHelper_sGetCString $lVarinatBomCS $z]
    lappend VbomList [DboTclHelper_sGetConstCharPtr $lVbomData]
    close $lBomReport
    dumpVarinatsubBoms $VbomList
  • PatEscher
    0 PatEscher over 1 year ago in reply to CadAP
    Thank you for the code. Unfortunately it is not exactly what we need.
    dumping out the BOM's of the variants etc. is what we do already.
    We really look for a way to fully automate the export of the variant.lst file from Capture to Allegro PCB Editor so that the variant information is available in Allegro PCB.
    So we would need to have exactly the same syntax understood by allegro than when going through the the export Variant.LST in Part Manager
    Patrick
  • Jeet
    +1 Jeet over 1 year ago in reply to PatEscher
    Try using the following TCL Code >
    set lNullObj NULL
    MenuCommand "14604"
    SetAutomationFlag 1
    "ExportVariantList" C:/TCL1 C:/Cadence/SPB_23.1/tools/capture/
    SetAutomationFlag 0
    Make sure the path variant.lst should have read/write permissions.
    "ExportVariantList" <path to dump variant.lst> <path to variant.cfg file>
    Let me know how it goes for you after performing the steps, are you able to generate variants.lst with tcl?
    • Vote Up +3 Vote Down
