  2. Allegro X Scripting - TCL
  3. How to open a .dsn file with tcl command?
  • State Verified Answer
  • Replies 12
  • Subscribers 13
  • Views 4461
ZB202408042725
ZB202408042725 over 1 year ago
I notice that if I want to open a .dsn file(without .opj file), the cammand is like that :
MenuCommand "57601"  | FileDialog  "OK" "D:/dsn/b.DSN" 2 | DialogBox  "OK" "D:/a.xml"
a.xml is complex file like this:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<DialogControls>
    <Control Type="EDIT" Enable="TRUE" Visible="TRUE" Id="15858">
        <Value><![CDATA[b]]></Value>
    </Control>
    <Control Type="AUTORADIO_BUTTON" Enable="FALSE" Visible="TRUE" Id="15880">
        <Value><![CDATA[0]]></Value>
        <Text><![CDATA[PSpicePWL]]></Text>
    </Control>
    <Control Type="AUTORADIO_BUTTON" Enable="FALSE" Visible="TRUE" Id="15881">
        <Value><![CDATA[1]]></Value>
        <Text><![CDATA[PSpiceAD]]></Text>
    </Control>
    <Control Type="EDIT" Enable="TRUE" Visible="TRUE" Id="15922">
        <Value><![CDATA[D:\dsn\]]></Value>
    </Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="1">
        <Value><![CDATA[OK]]></Value>
    </Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="2">
        <Value><![CDATA[Cancel]]></Value>
    </Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="57670">
        <Value><![CDATA[&Help]]></Value>
    </Control>
    <Control Type="AUTOCHECK_BOX" Enable="TRUE" Visible="TRUE" Id="15882">
        <Text><![CDATA[Enable PSpice Simulation]]></Text>
    </Control>
</DialogControls>
However, when I run this cammand, it is no always work! Sometime the b.dsn is opened successfully, sometime fail and block in the DialogBox. Therefore I want to know how this cammand work? What's the meaning of DialogBox?
  • ZB202408042725
    0 ZB202408042725 over 1 year ago
    By the way, I post the 2nd question here. I'm learning the OrCAD TCL Script. So I make a practice: place  port to all pins of a selected parts one by one, and connect the pin to the port. I will show my code below, the question is: when the script run, it occupy all my computer memory! I don't kown why this script need so much memory
    Here is my script(just for test, hence it is no elegant):
    set Inch 2.54
    set lStatus [DboState]
    set lInst [GetSelectedObjects]
    set PartX [expr [GetProperty {Location X-Coordinate}]/10*$Inch]
    set PartY [expr [GetProperty {Location Y-Coordinate}]/10*$Inch]
    set PartRef [GetProperty {Part Reference}]
    set lNullObj NULL
    set lIter [$lInst NewPinsIter $lStatus]
    set lPin [$lIter NextPin $lStatus]
    set lPinName [DboTclHelper_sMakeCString]
    set lPinNumber [DboTclHelper_sMakeCString]
    PlacePower [expr $PartX - 8*$Inch] [expr $PartY - 8*$Inch] "D:/Cadence/CandenceSPB17.4/Cadence/Cadence_SPB_17.4-2019/tools/capture/library/capsym.olb" "VCC_ARROW" "VCC"
    PlaceGround [expr $PartX + 38*$Inch] [expr $PartY + 38*$Inch] "D:/Cadence/CandenceSPB17.4/Cadence/Cadence_SPB_17.4-2019/tools/capture/library/capsym.olb" "GND_POWER" "GND"
    while {$lPin !=$lNullObj } {
        $lPin GetPinName $lPinName
        $lPin GetPinNumber $lPinNumber
        set PinName [DboTclHelper_sGetConstCharPtr $lPinName]
        set lStartPoint [$lPin GetStartPoint $lStatus]
        set lStartPointX [expr [DboTclHelper_sGetCPointX $lStartPoint]/10*$Inch]
        set lStartPointY [expr [DboTclHelper_sGetCPointY $lStartPoint]/10*$Inch]
        puts $lStartPointX
        puts $lStartPointY
        set lHotSpot [$lPin GetHotSpot $lStatus]
        set lHotSpotX [expr [DboTclHelper_sGetCPointX $lHotSpot]/10*$Inch]
        set lHotSpotY [expr [DboTclHelper_sGetCPointY $lHotSpot]/10*$Inch]
        set DelX [expr $lStartPointX-$lHotSpotX]
        set DelY [expr $lStartPointY-$lHotSpotY]
        if {$DelX > 0} {
            PlacePort [expr $PartX + $lStartPointX - 10*$Inch] [expr $PartY + $lStartPointY - $Inch] "D:/CADENCE/CANDENCESPB17.4/CADENCE/CADENCE_SPB_17.4-2019/TOOLS/CAPTURE/LIBRARY/CAPSYM.OLB" "PORTLEFT-R" $PinName
            PlaceWire [expr $PartX + $lStartPointX - 10*$Inch + 3*$Inch] [expr $PartY + $lStartPointY] [expr $PartX + $lStartPointX ] [expr $PartY + $lStartPointY]
        } elseif {$DelX < 0} {
            PlacePort [expr $PartX + $lStartPointX + 7*$Inch] [expr $PartY + $lStartPointY - $Inch] "D:/CADENCE/CANDENCESPB17.4/CADENCE/CADENCE_SPB_17.4-2019/TOOLS/CAPTURE/LIBRARY/CAPSYM.OLB" "PORTRIGHT-L" $PinName
            PlaceWire [expr $PartX + $lStartPointX + 7*$Inch ] [expr $PartY + $lStartPointY] [expr $PartX + $lStartPointX ] [expr $PartY + $lStartPointY]
        puts [format "%s.%2s:%s" $PartRef [DboTclHelper_sGetConstCharPtr $lPinNumber] $PinName]
        unset PinName
        unset lStartPoint
        unset lStartPointX
        unset lStartPointY
        unset lHotSpot
        unset lHotSpotX
        unset lHotSpotY
        unset DelX
        unset DelY
        unset lPin
        #get the next pin of the part
    delete_DboPartInstPinsIter $lIter
  • CadAP
    0 CadAP over 1 year ago in reply to ZB202408042725
    Hi ZB202408042725,
    For opening design please try below command and do not provide any extra arguments:
    MenuCommand "57601"  | FileDialog  "OK" "D:/dsn/b.DSN" 2  ; # if opening .dsn
    MenuCommand "57601"  | FileDialog  "OK" "D:/dsn/b.opj" 1 ; # if opening .opj.
    Please try and let me know your observations.
    For second concern,
    Please try to check the time required by api to provide the information by using command time {<tcl_api/proc>}
    Also check if any other program does not overload the processors.
    Regards
    CadAP
  • ZB202408042725
    +1 ZB202408042725 over 1 year ago in reply to CadAP
    em, MenuCommand "57601"  | FileDialog  "OK" "D:/dsn/b.DSN" 2 ,this command return nothing, does it open the designed invisibly? I want to open the design just like what's happending when I click File->Open->Design and choose the design file as follow pic:
  • CadAP
    Hi ZB202408042725,
    What do you mean by invisibly? Are you not able to see the design open in Orcad Capture canvas?
    I believe the FIle-->Open--> Design , we are using MenuCommandID
  • ZB202408042725
    0 ZB202408042725 over 1 year ago in reply to CadAP
    After the command :MenuCommand "57601"  | FileDialog  "OK" "D:/dsn/b.DSN"  had been executed, this is nothing like this pic:
    By the way ,the B.DSNlck is generated:
