  2. Allegro X Scripting - TCL
  3. TCL Code to create a series of schematic symbol with different...
  • Subscribers 12
  • Views 1427
TCL Code to create a series of schematic symbol with different properties
RohitRohan
RohitRohan over 1 year ago
Hai Community,
I want to create a series of schematic symbol with the different properties.
Like I have created one resistor symbol, or I have taken one resistor symbol from the default libraries of OrCAD Capture, and want to place around 200 resistor in the schematic design. (Same symbol)
The catch is each and every schematic symbol (R1 to R200) should have different properties, like if the R1 has PCB Footprint of Example 0805, then r2 should have different property. Not only one property but multiple properties.
Can it be possible using the TCL coding, if possible can anyone share the TCL code for me please.
Rohit Rohan
  • Jeet
    0 Jeet over 1 year ago
    Which different properties you are looking for in the schematic symbol apart from PCB Footprint?
  • RohitRohan
    0 RohitRohan over 1 year ago in reply to Jeet
    Like for example if Resistor R1 has properties of PCB footprint, Value, Part number and Resistor R2 should have all the properties of R1 along with an additional property of Manufacture details.
    Similarly the properties for R3 might differ from R1 and R2.
    Is there any way to use TCL coding to be able to create multiple parts of the same symbol at once and also be able to assign different properties to each part.
  • CadAP
    0 CadAP over 1 year ago in reply to RohitRohan
    Hi Rohit,
    Yes, it is possible to place multiple instances of the same symbol and change all the property values according to your requirements.
    I would like to suggest creating a csv file with the header Ref_Des_NUmber, Property Name, Property Value.
    Now read ref_des_number from the schematic and change the property value read from the csv.
    Hope it helps .
