  2. Allegro X Scripting - TCL
  3. TCL Replace all the Pat on that page
  • State Verified Answer
  • Subscribers 12
  • Views 2310
ZH202409115233
ZH202409115233 over 1 year ago
I took a part from the CIS library and I want to replace all similar components on the page, such as a resistor 0201 with a 0402 from the CIS library (I will first put the 0402 from the CIS into the page to obtain its information).Could you please tell me how to use TCL script?
  • rg13
    0 rg13 over 1 year ago
    This is being looked upon. Once script is ready, it will be shared.
  • CadAP
    +1 CadAP over 1 year ago in reply to rg13
    Hi ZH202409115233
    Please the try the below tck code.
    It will dump the properties of a CIS library part (part number start with EMA) and then replace the other selected instance with the CIS part library.
    Please check and lt me know your feedback.
    proc dumpproperties {} {
    set lNullObj NULL
    set lCounter 0
    set lPropertieslist {}
    set lStatus [DboState]
    set lPartNameCString [DboTclHelper_sMakeCString "Part_Number"]
    set lPartValueCString [DboTclHelper_sMakeCString]
    set lSelectedParts [GetSelectedObjects]
    #create the input/output parameters
    set lPrpName [DboTclHelper_sMakeCString]
    set lPrpValue [DboTclHelper_sMakeCString]
    set lPrpType [DboTclHelper_sMakeDboValueType]
    set lEditable [DboTclHelper_sMakeInt]
    foreach part $lSelectedParts {
    set lStatus [$part GetEffectivePropStringValue $lPartNameCString $lPartValueCString]
    set lPartValue [DboTclHelper_sGetConstCharPtr $lPartValueCString]
    if {[regexp {EMA} $lPartValue ] == 1} {
    set lPropsIter [$part NewEffectivePropsIter $lStatus]
    #get the first effective property
    set lStatus [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
    while {[$lStatus OK] == 1 && [DboTclHelper_sGetInt $lEditable] == 1} {
    set lPropname [DboTclHelper_sGetConstCharPtr $lPrpName]
    set lPropVal [DboTclHelper_sGetConstCharPtr $lPrpValue]
    # puts "$lPropname :== $lPropVal"
    # puts [DboTclHelper_sGetInt $lEditable]
    lappend lPropertieslist $lPropname $lPropVal
    #placeholder: do your processing for $lPrpName $lPrpValue $lPrpType $lEditable
    #get the next effective property
    incr lCounter
    delete_DboEffectivePropsIter $lPropsIter
    if {$lCounter > 0} {
    return $lPropertieslist
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lPkgCSName [DboTclHelper_sMakeCString]
    set lPartRefernce [DboTclHelper_sMakeCString]
    set lPartRefernce1 [DboTclHelper_sMakeCString]
    set lSelcedtedObj [lindex [GetSelectedObjects] 0]
    # puts $lSelcedtedObj
    set lAllDbProps [dumpproperties]
    set lPkgName [$lSelcedtedObj GetPackage $lStatus]
    set lLibPart [$lSelcedtedObj GetPart $lStatus]
    set lDboDevice [$lSelcedtedObj GetDevice $lStatus]
    set lSourcePckgnName [$lSelcedtedObj GetSourcePackageName $lPkgCSName]
    set lRef [$lSelcedtedObj GetReference $lPartRefernce]
    set lPartRef [DboTclHelper_sGetConstCharPtr $lPartRefernce]
    puts $lPkgName
    puts $lLibPart
    puts $lDboDevice
    puts $lPartRef
    puts [DboTclHelper_sGetConstCharPtr $lPkgCSName]
    set lselob [GetSelectedObjects]
    foreach obj $lselob {
    set lPage [$obj GetOwner]
    set lRef1 [$obj GetReference $lPartRefernce1]
    set lPartRef1 [DboTclHelper_sGetConstCharPtr $lPartRefernce1]
    puts $lPartRef1
    if {$lPartRef1 != $lPartRef} {
    puts "changing"
    $lPage ReplaceInst $obj $lPkgCSName $lLibPart $lDboDevice $lStatus 1 1 1 1 1
    DboTclHelper_sEvalPage $lPage
    Menu "File::Save"
    Menu "View::Zoom::Redraw"
    puts "[llength $lAllDbProps]"
    for {set i 0} {$i <= [expr {[llength $lAllDbProps]/2}]} {incr i} {
    # puts [lindex $lAllDbProps $i]
    # puts [lindex $lAllDbProps [expr {$i + 1}]]
    set lpropname [DboTclHelper_sMakeCString [lindex $lAllDbProps $i]]
    set lpropvalu [DboTclHelper_sMakeCString [lindex $lAllDbProps [expr {$i + 1}]] ]
    # puts $lpropname
    # puts $lpropvalu
    # $obj SetEffectivePropStringValue $lpropname $lpropvalu 0
    $obj SetUserPropStringValue $lpropname $lpropvalu
    incr i
  • ZH202409115233
    0 ZH202409115233 over 1 year ago in reply to CadAP
    I understand the logic of this code, but the code lines # $obj SetEffectivePropStringValue $lpropname $lpropvalu 0 and $obj SetUserPropStringValue $lpropname $lpropvalu are not working, why?(Cadence 17.2)
  • CadAP
    0 CadAP over 1 year ago in reply to ZH202409115233
    ZH202409115233  it should work.
    Can you let me know the current hotfix for you SPB17.2 version?
  • ZH202409115233
    Thank you. That works
