  2. Allegro X Scripting - TCL
  3. how to get a report of not displayed property and make it...
  • State Verified Answer
  • Subscribers 13
  • Views 2737
how to get a report of not displayed property and make it displayed via TCL script
fSeyer
fSeyer over 1 year ago
Hi
How to get all parts specific package and make them display via TCL script?
and any way can generate a report for designator which package are not displayed?
example:
i want to get report of package 0402 resistors which are not displayed and i got options to display one at a time or one by one.
i saw this to code get all 0402 but doesn't work well
set lAllRes [CapFindObjects $COrFindFilterDlg_PARTS {0402*}]
foreach resistor $lAllRes {
UnSelectAll
set res [lindex $resistor 0]
set Id [$res GetId [DboState]]
SelectObjectById $Id
SetDisplayType {Package} {1}
UnSelectAll
  • CadAP
    +1 CadAP over 1 year ago
    Hi fSeyer ,
    Please find the below code for your requirement.
    Please do let me know your feedback after trying.
    Please make change for below line if you want to change property name and value.
    For example, below shared code I have filter out Package SIze and Value.
    if {$lPropName == "Package Size" && $lPropValue == "0402"}
    Please copy and paste below code in text file and save it as .tcl.
    set lStatus [DboState]
    set lDesign [GetActivePMDesign]
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    set lNullObj NULL
    set lPrpName [DboTclHelper_sMakeCString]
    set lPrpValue [DboTclHelper_sMakeCString]
    set lPrpType [DboTclHelper_sMakeDboValueType]
    set lEditable [DboTclHelper_sMakeInt]
    # set lPropNameCStr [DboTclHelper_sMakeCString "Tolerance"]
    set rotation 0
    set logfont [DboTclHelper_sMakeLOGFONT]
    set lReferenceName [DboTclHelper_sMakeCString]
    set color $::DboValue_DEFAULT_OBJECT_COLOR
    # set displocation [DboTclHelper_sMakeCPoint ]
    UnSelectAll
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    #placeholder: do your processing on $lSchematic
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    while {$lPage!=$lNullObj} {
    #placeholder: do your processing on $lPage
    set lPartInstsIter [$lPage NewPartInstsIter $lStatus]
    #get the first part inst
    set lInst [$lPartInstsIter NextPartInst $lStatus]
    while {$lInst!=$lNullObj} {
    #dynamic cast from DboPartInst to DboPlacedInst
    set lPlacedInst [DboPartInstToDboPlacedInst $lInst]
    if {$lPlacedInst != $lNullObj} {
    $lPlacedInst GetReference $lReferenceName
    set refdes [DboTclHelper_sGetConstCharPtr $lReferenceName]
    #placeholder: do your processing on $lPlacedInst
    set lPropsIter [$lPlacedInst NewEffectivePropsIter $lStatus]
    #get the first display property on the object
    if {[regexp -nocase {^C} $refdes] == 1} {
    # puts $refdes
    set lDProp [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
    while {[$lDProp OK] == 1 } {
    # $lDProp -delete
    set lPropName [DboTclHelper_sGetConstCharPtr $lPrpName]
    set lPropValue [DboTclHelper_sGetConstCharPtr $lPrpValue]
    # puts [DboTclHelper_sGetConstCharPtr $lPrpName]
    if {$lPropName == "Package Size" && $lPropValue == "0402"} {
    puts $lPropName
    puts $lPropValue
    set partId [$lPlacedInst GetId $lStatus]
    SelectObjectById $partId
    # SetDisplayType {Package Size} 1
    set partBBox [$lPlacedInst GetBoundingBox]
    set partleftPointXY [DboTclHelper_sGetCRectTopLeft $partBBox]
    if {[$lPlacedInst GetDisplayProp $lPrpName $lStatus] == $lNullObj } {
    set pNewDispProp [$lPlacedInst NewDisplayProp $lStatus $lPrpName $partleftPointXY $rotation $logfont $color]
    $pNewDispProp SetDisplayType $::DboValue_VALUE_ONLY
    UnSelectAll
    delete_DboEffectivePropsIter $lPropsIter
    #get the next part inst
    delete_DboPagePartInstsIter $lPartInstsIter
    #get the next page
    delete_DboSchematicPagesIter $lPagesIter
    #get the next schematic view
    delete_DboLibViewsIter $lSchematicIter
    ZoomOut
    • Vote Up +2 Vote Down
  • fSeyer
    0 fSeyer over 1 year ago in reply to CadAP
    Hi CadAP,
    The code works as intended, Thank you!
  • Gelzone
    0 Gelzone 3 months ago in reply to CadAP
    CadAP
    Sorry for bothering, I have tried the code and it worked well except the position of the property name.
    The code:
    I guess it will make the part has a very large frame and the property name will show at the bottom-right of the frame.
    Can you help to check it out?
  • fSeyer
    0 fSeyer 3 months ago in reply to Gelzone
    try to replace with this, you can adjust depend on your reference
    set lRot [$lPlacedInst GetRotation $lStatus]
    if { $lRot == 0} {
    set partleftPointXY [DboTclHelper_sMakeCPoint 60 -8]
    if { $lRot == 1} {
    set partleftPointXY [DboTclHelper_sMakeCPoint 20 30]
  • Gelzone
    0 Gelzone 2 months ago in reply to fSeyer
    Sorry for late.
    It helps for now.
    But I wonder if there are several different size of the components, maybe I need to change the code.
    I am not the RDs to create schematic so I will make this as my solution now.
    Thanks.
