  2. Allegro X Scripting - TCL
  3. Get part occurrences reference designators and pin numbers...
  • State Verified Answer
  • Answers 1
  • Subscribers 13
  • Views 3276
Get part occurrences reference designators and pin numbers connected to a flat net
VB202505089850
VB202505089850 7 months ago
I want to iterate through all the flat nets in my hierarchical design in OrCAD Capture using a Tcl/Tk script. For each net, I need to print the flat net name, the reference designators of the components it is connected to, and the relevant pin numbers of these components (for example: N4958340: U1.2 R11.1 U3.1, N9487723: U1.1 U1.3).
However, I am having trouble retrieving the reference designators of the part occurrences. I can only access the reference designators of the part instances, but that is not what I need. Below is my code so far—perhaps someone can help me:
variable cstr DboTclHelper_sMakeCString
variable str DboTclHelper_sGetConstCharPtr
set dsn [GetActivePMDesign]
set lStatus [DboState]
set lNullObj NULL
# Get iterator for flat nets
set netIter [$dsn NewFlatNetsIter $lStatus]
if {$netIter == $lNullObj} {
  return
# Iterate over flat nets
set net [$netIter NextFlatNet $lStatus]
while {$net != $lNullObj} {
  # Get net name
  set netNameCStr [$cstr]
  if {[catch {$net GetName $netNameCStr}]} {
    set netName ""
  } else {
    set netName [$str $netNameCStr]
  if {$netName != ""} {
    # Get port (pins) connected to this net
    set pinIter [$net NewPortOccurrencesIter $lStatus]
    set pinList {}
    set pin [$pinIter NextPortOccurrence $lStatus]
    while {$pin != $lNullObj} {
      set pinInst [$pin GetPortInst $lStatus]
      # Get reference designator into $refdes
      # How to get it? I need to find the part occurrence somehow, either from the port occurrence or from the flat net, but how?
      # Get pin number
      set pinNumCStr [$cstr]
      if {[catch {$pinInst GetPinNumber $pinNumCStr}]} {
        set pinNum ""
      } else {
        set pinNum [$str $pinNumCStr]
      if {$refdes != "" && $pinNum != ""} {
        lappend pinList "$refdes.$pinNum"
    delete_DboFlatNetPortOccurrencesIter $pinIter
    # Store the net and its pins (sorted for consistency)
    if {[llength $pinList] > 0} {
    dict set netsdict $netName [lsort $pinList]
delete_DboDesignFlatNetsIter $netIter
  • andakConsultingLtd
    0 andakConsultingLtd 7 months ago
    This one's very tricky as you need to do processing of the net from hierarchy to flat. There will be a lot to iterate and check.
    An easier way is to generate the netlist from Capture and parse the generated netlist file with your TCL script. This one's much easier and grants:
    1. Your netlist generates without errors
    2. You don't miss anything during net processing (you might have duplicated net aliases, ports and offpage ports).
    3. A valid, reliable and simple file to process each time you want to do your tricks.
    4. What you get in the netlist is exactly what goes into PCB
    You can generate the netlist manually or automatically, through the TCL (replay GUI actions)
    Look in the ./allegro/pstxnet.dat file. The flatnet structure is quite simple. You get the net_name and then the node_name which is basically the pin
    NET_NAME
    'ADC12_4'
     '@SCM-0024_A.SCM-10013(SCH_1):ADC12_4':
     C_SIGNAL='@\scm-0024_a\.\scm-10013\(sch_1):adc12_4';
    NODE_NAME    J26 4
     '@SCM-0024_A.SCM-10013(SCH_1):INS16692064@ADK.TSW-106-07-G-D.NORMAL(CHIPS)':
     'B2':;
    NODE_NAME    J8 1
     '@SCM-0024_A.SCM-10013(SCH_1):INS16782590@ADK.SMA CONNECTOR.NORMAL(CHIPS)':
     '1':;
    NODE_NAME    R4 1
     '@SCM-0024_A.SCM-10013(SCH_1):INS16782622@ADK.RES.NORMAL(CHIPS)':
     '1':;
  • CadAP
    0 CadAP 7 months ago
    @VB202505089850
    Please find the the code below i have added below section in your code to get placed part and then refdes.:
    set lPropRefdesStr [DboTclHelper_sMakeCString "Part Reference"]
    set lPropValStr [DboTclHelper_sMakeCString]
    set lPlacedINst [$pinInst GetOwner]
    set lState [$lPlacedINst GetEffectivePropStringValue $lPropRefdesStr $lPropValStr]
    set refdes [DboTclHelper_sGetConstCharPtr $lPropValStr]
    set lNullObj NULL
    return
    # Get net name
    set netName ""
    } else {
    set pinList {}
    # Get pin number
    set pinNum ""
    } else {
  • VB202505089850
    0 VB202505089850 7 months ago in reply to andakConsultingLtd
    Thank you andakConsultingLtd , it is an interesting idea. I will try it.
  • VB202505089850
    0 VB202505089850 7 months ago in reply to CadAP
    Thanks CadAP , but i think it will only give me the Ref Des of the part instances, isn't it? I need the Ref Des of the part occurrences.
    Since you use:
    Where lPlacedINst is the part instance.
  • CadAP
    +1 CadAP 7 months ago in reply to VB202505089850
    VB202505089850
    Please updated code which helps to get part occurrences refdes.
    I have added below proc to get part occurences in your code.
    proc DumpPartOccurrences {lObj} {
    # set lObj [GetSelectedObjects]
    set lPatOcc {}
    foreach obj $lObj {
    set lOccCount [$obj GetOccurrencesCount]
    for {set i 0} {$i<$lOccCount} {incr i} {
    set lOcc [$obj GetOccurrencesAtPos $i]
    lappend lPatOcc $lOcc
    return $lPatOcc
    set lPatOcc {}
    foreach obj $lObj {
    return $lPatOcc
    set lNullObj NULL
    return
    # Get net name
    set netName ""
    } else {
    set pinList {}
    set lPlacedOcc [DumpPartOccurrences $lPlacedINst]
    foreach lOcc $lPlacedOcc {
    set lState [$lOcc GetEffectivePropStringValue $lPropRefdesStr $lPropValStr]
    # Get pin number
    set pinNum ""
    } else {
