  3. System Capture Injected Property DE-HDL not Visible
  • Replies 7
  • Subscribers 30
  • Views 11193
PIPE
PIPE over 3 years ago
Hello All,
What is the way todo this in System Capture.
Currently only the Key Propertys are Visible by default and can be switched off.
In DE_HDL it reads the ppt_optionset.dat File.
I have played with this but unfortinatly this works on system capture.
Can you give me some instruction.
Peter
  • PIPE
    0 PIPE over 3 years ago in reply to srish09
    Hallo, I try it tomorrow's.
    Part.ptf added by edit preferences, but don't work.
  • srish09
    0 srish09 over 3 years ago in reply to PIPE
    Try adding the libraries as well using Edit > Preferences. Or if libraries are already added through CDS_SITE, add the ppt directive to your site.cpm and see if that works.
    START_GLOBAL
    ppt '$CDS_SITE/<path_to_ptf>/part.ptf'
    END_GLOBAL
