  2. Allegro X Capture CIS
  3. to undo a delete command
  • Subscribers 43
  • Views 13580
masamasa
masamasa over 5 years ago
hello
is there a way to undo a delete function?
i always use a delete key on the keyboard when i want to delete an object.
but when i do it, i can not undo the delete.
  • redwire
    0 redwire over 5 years ago
    works fine here...are you talking about PCB or Schematic?  Schematic follows Ctrl-Z undo and PCB follows an icon or Edit undo command
  • masamasa
    0 masamasa over 5 years ago in reply to redwire
    thank you for your reply.
    i use pcb editor and i do not use an icon or edit on the menu.
    i would like to find out a way to undo the delete by pressing a key on the keyboard.
  • redwire
    0 redwire over 5 years ago in reply to masamasa
    Simply create your own key using the funckey command and map it to the undo
