  2. Allegro X Capture CIS
  3. Back Annotate from Allegro to bring in component location...
  • Replies 14
  • Subscribers 44
  • Views 8963
Back Annotate from Allegro to bring in component location and board side using "pickdata" broken on 17.4
JERATSSI
JERATSSI over 4 years ago
We generate our bill of materials from the schematic and one of the things we need is the component board side.  A long time ago Ole Ejlersen wrote a script called symboldata that creates a swap file I could back annotate into the schematic to bring in that information so I can export a report with all the components and their placement info.  It worked fine on 17.2 but now that I've gotten to 17.4 it appears to be broken.
This is the example of the output
;Backannotation file with pick and place data
;from Cadence Allegro to Capture and Capture CIS
.Section3 UpdateProperties Parts
"{Reference}" "COMPX" "COMPY" "COMPROT" "COMPSIDE"
"C11" "-142" "-764" "180.000000" "BOT"
"C12" "-266" "-879" "180.000000" "BOT"
"C13" "-206" "-627" "90.000000" "TOP"
When I try back annotating with or without the generate board feedback box selected I get:
"Encountered an improper argument."
I'm guessing by this message and another thread about compatibility being lost with PADS that back annotate has changed significantly and my script will no longer work.  Is there a new way to get this information into my schematic component properties so I can do my standard BOM reports again?
  • JERATSSI
    0 JERATSSI over 4 years ago
    I've heard from EMA that cadence removed the layout tab from back annotate and are not considering replacing it.  So looks like the BOM functionality needed for our ERP system is now broken.  I'll have to revert to 17.2.
  • redwire
    0 redwire over 4 years ago in reply to JERATSSI
    All of the data from the BRD file should be backannotated using the PCB Editor mode, not Layout mode.  That includes pin swaps, component swaps, etc..  And you can add all of your user data as well.  I think you are doing something wrong by trying to use Layout mode.
  • JERATSSI
    0 JERATSSI over 4 years ago in reply to redwire
    I'm using a script generated by someone working for OrCAD many years ago.  It creates a swap file that contains component location and most importantly board side information, when using back annotate it would bring that information into the part properties so I could export a BOM that was separated by board side.  That functionality is broken on 17.4.  When I asked Cadence they forwarded me to EMA who said that Cadence removed support for the "layout" tab of back annotate which I had been using and they don't plan on bringing it back. They said I'd have to write a custom TCL script to read in the board and update the schematic, they don't see a better solution.
  • redwire
    If you are using OrCAD schematic and OrCAD PCB (aka Allegro) then the "Layout" backannotation is the incorrect method despite your claim.  It has *always* been through the PCB Editor mode.  The Layout tab was there to support other tools only which have been removed.
    All of your data can still be injected into your schematic if you use OrCAD schematic via PCB Editor backanno.  It just requires setting up the config file to import/export user defined properties.
  • excellon1
    0 excellon1 over 4 years ago in reply to redwire
    Hi Red.
    In the pcb editor the mirrored status of a symbol/footprint shows up under "Component Report", the header for the report shows "SYM_MIRROR" if the symbol is mirrored on the bottom side of the board.
    How to get this Mirrored status back to the schematic so a BOM can be generated & show that mirrored status ?
    You mentioned the Allegro.cfg file so testing a few things here I added SYM_MIRROR=YES to the [ComponentInstanceProps] section to see if BackAnno would work. This is probably the wrong method as I could not get it to work.
    Any Clues on how to do it ?
    BTW the bom out of Allegro is pretty good and have used this alot, more curious than anything on how to pass that SYM_MIRROR info back to capture. Not a got to have for me :)
    Thanks..
  • redwire
    0 redwire over 4 years ago in reply to excellon1
    The title of the column is "SYM_MIRROR" but that is not an actual component property.  You can only pass properties attached to components, nets, etc back to OrCAD.
    So what to do?
    You can add a property to the component and pass it back  Call it SYM_MIRROR and pass it back.  I just did that and it works great.
    You can write some SKILL code that digs down to the component property for mirrored side and then pass that back via an attached component property.
    You can use the logic rename tool and add a character such as "T" or "B" to the component based on its placement side then that will tell you which side.
    You can use the OrCAD property import tool and add it after adjusting the old SKILL tool file out there which I think you're using...
    But out of curiosity, why do you need to do this?  I've been doing this my whole career and never had to separate these on the schematic side; just in the placement data. I did use to add 500 to the bottom components to quickly identify top from bottom but the BOM was always the same (all identical parts on the same line).   I'd like to learn why you do this and hopefully someone more experienced will chime in on an even better method.
  • excellon1
    Hi Red
    So on this a couple of things. Over the years I have see this on BOM's sometimes called out as a line item header called "Location". The idea is so that at a glance a assy house can look at the BOM and see what side of the board components are on. This would be kind of a value add and is useful in particular for SMD builds that may have components on the bottom side of the board.
    For rework techs it is also handy in conjunction with the schematic.
    In Allegro/Orcad PCB Editor you can generate a BOM fairly easily that can include the "Mirror" info. No need to modify footprints/symbols to do this. This would be the method I use.
    It seems to me that there should be an easier method to get this info back to the schematic. Doing Skill files or bit twiddling on Orcad Symbols just to generate a BOM out of capture is a bit of a heavy lift. It is kind of like this. When you purchase Capture it comes with a massive amount of symbols which is great. Though those symbols are pretty useless for a real design. The symbols do not contain attributes which are used so that Orcad Capture can generate a viable BOM. Things like MFR/PN, Manufacturer etc or basically any property that one would see on a typical BOM.
    CIS does address and makes things a bit easier. I dunno if it is possible to convey the PCB Sym_Mirror info back to CIS.
    As I mentioned earlier it's not a got to have for me. But I can see that if a company was actively structured so that their BOM's needed to have this info it may well present a road-block for them from the schematic generation level if they do indeed use the schematic to generate a viable BOM.
    Thanks.
  • excellon1
    Hi Red
    Thanks.
  • AvengerThanos
    0 AvengerThanos over 4 years ago in reply to excellon1
    Irrespective of version still .swp file in generated in project directory. With layout being removed user lost scope and mode options.
