  2. Allegro X Capture CIS
  3. 2 names on the same net
  • Replies 9
  • Subscribers 44
  • Views 13341
LSAUGE
LSAUGE over 3 years ago
Good morning,
For a project, I have a force and a sense line that are connected to the same point. Is there a way in OrCAD Capture to differentiate these two lines (different names), even if they are technically on the same net ? It would be easier to differentiate them in the layout then.
Thanks in advance,
Loïc
  • EnottonE
    0 EnottonE over 3 years ago
    For these purposes, I use specially created components in the form of resistors of sizes 0603 or 0805, I call them "net short" on the schematic diagram. On the PCB, they look like smd resistors, but there is a shape under them, it will need to assign the "net short" property, select circuit 1, then circuit 2 and execute the "complete net short" command from the context menu by right-clicking.
  • EnottonE
    or you can do this: https://youtu.be/OplkPt5CFF0
  • LSAUGE
    0 LSAUGE over 3 years ago in reply to EnottonE
    Thanks a lot for the explanation.
    I manage to short the 2 nets in OrCAD Capture but in OrCCAD PCB it doesn't behave like I would like :
    I'd like the AVSS pad to be connected to the AVSS plane, but not the AVSS_S pad (sense line). How can I do that ?
  • EnottonE
    0 EnottonE over 3 years ago in reply to LSAUGE
    don't remember exactly, I'll clarify tomorrow at work, but it seems that the pad can set the No_Shape_Connect property or something like that, I don't remember from memory. Or check the pad property to see if a solid fill type is set for shape, thermal connection type.
  • steve
    0 steve over 3 years ago in reply to LSAUGE
    Take a look at PCB Editor Tips and Tricks (parallel-systems.co.uk) page 30 has a void_same_net methid which can be used for sense lines.
