  2. Allegro X Capture CIS
  3. i finished my circuit on capture cis but got this error...
  • Subscribers 44
  • Views 3231
i finished my circuit on capture cis but got this error after trying to simulate "pin B in template not found on R1"
lightn
lightn over 3 years ago
i am obligated to use orcad 10.5 because its the one used in ly university
here is what the circuit supposed to look like on the data sheet:
here is how i made it on cis capture:
and this is the error i got:
any help?
  • oldmouldy
    0 oldmouldy over 3 years ago
    Check the PSpice Template property value on the resistor. It sounds like there is a %B in the value whereas, typically, a resistor would be using %1 and %2 to map the graphical symbol Pin Names to the underlying model nodes. Just to mention that 10.5 was only around from 2005 to 2006.
  • lightn
    0 lightn over 3 years ago in reply to oldmouldy
    thank you! i found it in analog.lib
    also unfortunately i cant use a higher version because i have to use the same version as  my university professors
    also i got this error afterward
    its because there is missing input data in the parameters like the one in the input data section shown in the paper sheet but i couldn't find a tutorial on how to add them
