  2. Allegro X Capture CIS
  3. In a multi-schematic project (hierarchical design), can...
  • Subscribers 44
  • Views 7933
In a multi-schematic project (hierarchical design), can each schematic have its own annotation and its own PCB board?
vancraft
vancraft over 3 years ago
Hello, I just moved to a new company and started using Capture CIS 17.4 and Allegro not for long.
I am making a project with many schematics, say 2 schematics: schematic1 and schematic2. Each schematic may have 1 page or several pages.
1) Question 1: Now I want to do annotation of each schematic seperately. For example, schematic 1 has two inductors and schematic has three inductors. I want refdes of inductors in schematic 1 is L1, L2; and refdes of inductors in schematic 2 is L1, L2, L3 (refdes of each schematic should start from 1). However, I couldn't find a way to do so. When I did annotation, the entire design will have L1, L2, ..., L5. If I try to manually put the refdes, the DRC will have error of duplicate references. So, the question is: can I annotate schematic seperately without causing DRC errors? If yes, how? If no, why not? I think it is common sense to have refdes of each PCB board start from 1.
2) Question 2: Can I generate PCB board for each schematic? Schematic1 will have board 1 and schematic 2 will have board 2. If yes, how can I do that? When I tried to create netlist, there is no option of creating netlist of each schematic, the created netlist is for the entire design.
I tried to find the answers for the 2 questions for many days and couldn't find it yet.
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago
    - To annotate page wise, you can use advanced annotation. It gives you control to annotate page wise, component wise & property wise.
    - Cadence doesn't multi-board creation with same schematics. But you can use netlist ignore property to netlist only certain components.
    For example you have 2 page schematics. Page 1 you want as one board then for page 2 components set the netlist ignore property true so only page 1 components will be netlisted & you can create board 1
  • vancraft
    0 vancraft over 3 years ago in reply to Schulz Jordan
    Hello, Schulz. Sorry for being late reply. I was stuck with another busy project so I forgot to reply your answer. I think I didn't make it clear enough for you to understand my question.
    1) I want to do annotation where every schematic (not page) starts from 1. But if I do that, the DRC will generate errors: "duplicate reference". For example, I make a project with 2 schematics, each schematic has 1 page:
    As you can see, both schematic 1 and schematic 2 have 3 capacitors whose reference starts from 1 (C1, C2, C3). However, Orcad does not allow this. It generates the errors: "duplicate reference". Why? schematic 1 and schematic 2 are supposed to be seperated boards, it should be totally fine if they have the same references, why is there an error?. Is there any way to ignore/remove these errrors?
    2) I want to generate a PCB board for each schematic, not page. So, look at the above example, I want one board for schematic 1, and another board for schematic 2. But when I tried to create netlist, it generated the netlist of the entire design. I couldn't find an easy way to generate a board for each schematic. Why so? What is the point of having multi-schematic project if you cannot easily make a board for each schematic? If you cannot do so, what's difference between page and schematic?
