  2. Allegro X Scripting - TCL
  3. Accessing occurrence properties from TCL script?
  • Subscribers 12
  • Views 5385
Valueduser
Valueduser over 3 years ago
I have a design that incorporates hierarchical elements and was annotated using the recommended method (using occurrences).  So when I look at the the properties of say a capacitor, I see a white field with the Instance properties and a yellow field with the occurrence properties.  If I iterate over the parts on a page and call the GetReferenceDesignator method it returns the instance refDes.  Does anyone know how I would get occurrence refDes (the value that shows up in the yellow field)?  The TCL API reference is pretty sparse on details, if anyone could point me in the right direction it would be greatly appreciated.  Below is the code I am using to iterate over the parts on a page:
proc iterateParts {pageObject} {
    set lStatus [DboState]
    set lPartInstsIter [$pageObject NewPartInstsIter $lStatus]
    set refDesList []
    #initialize a Cstring variable for holding object names
    set name [DboTclHelper_sMakeCString]
    #get the first part inst
    set lInst [$lPartInstsIter NextPartInst $lStatus]
    set lNullObj NULL
    while {$lInst!=$lNullObj} {
        #dynamic cast from DboPartInst to DboPlacedInst
        set lPlacedInst [DboPartInstToDboPlacedInst $lInst]
         if {$lPlacedInst != $lNullObj} {
         #placeholder: do your processing on $lPlacedInst
         iterateProps $lPlacedInst
         $lPlacedInst GetReferenceDesignator $name
         lappend refDesList [DboTclHelper_sGetConstCharPtr $name]
    #get the next part inst
    delete_DboPagePartInstsIter $lPartInstsIter
    #sort list
    set refDesList [lsort $refDesList]
    return $refDesList
  • Diego cmre
    0 Diego cmre over 3 years ago
    I think your code can traverse only instances, try to use example on chapter "3.2.28.2 Iterate over instance occurrence hierarchy" page 40 of OrCAD Capture TCL/Tk Extensions Revision: 1.2 Apllication note.
    Regards
  • Valueduser
    0 Valueduser over 3 years ago in reply to Diego cmre
    Since I made my original post, I found the "Compare Designs" example.  When you use it, it shows both the instance and the occurrence reference designators, so I know it's possible.  I haven't had the chance to look too closely at the actual example code yet.
