  2. Allegro X Capture CIS
  3. Can I connect several PCB Boards together using connectors...
  • Subscribers 43
  • Views 6345
Can I connect several PCB Boards together using connectors in hierarchical blocks.
OussDeCouette
OussDeCouette over 3 years ago
I'd like to connect different boards together with connectors without having to route every signal one by one.
For example, I have Connector J1 on Board 1 (routed with the different components of Board 1) and Connector J2 on Board 2 (routed with the different components of Board 2), and the goal is to connect J1 and J2 inside the hierarchical blocks page.
Like in the beginning of this video https://youtu.be/fIVOAzPHb14
  • rg13
    0 rg13 over 3 years ago
    Option shown in this video does not come with standard tool installation. These are some Add-ons which are overlaid on standard tool installation. You can directly contact the company which has posted this video.
