  2. Allegro X Capture CIS
  3. The convenience way to change many alias names by using...
  • State Suggested Answer
  • Answers 1
  • Subscribers 47
  • Views 9036
The convenience way to change many alias names by using OrCAD Capture 16.6.
KENTOKENTOKEN
KENTOKENTOKEN over 3 years ago
Hello
I want to know about the convenience way to change many alias names by using OrCAD Capture 16.6.
I want to change these 20 alias(①) names at once.(For example,by making lists.)
By drag and choice nets,and press ctrl+E, I can make the net name schematic net list(②).
However, I can't choice the name except which can be selected from the pull-down.
Then,I have to double click alias names, and edit net alies name from Edit Net Alias window 20 times.(③)
It is troublesome,so please tell me1 the way to change alias names at once.
  • jgregoire
    0 jgregoire over 2 years ago
    It's the same way in 17.2 and 17.4. Very frustrating when I have a ton of aliases to edit.
  • steve
    0 steve over 2 years ago
    You can try this Quick Tutorial: How to Edit Net Aliases in bulk in OrCAD Capture |  PCB Design Insights (ema-eda.com)
