  2. Allegro X Scripting - TCL
  3. Using TCL script to find and change property of a part in...
  • State Verified Answer
  • Subscribers 12
  • Views 6058
Using TCL script to find and change property of a part in the scope of whole design file
YuanYan
YuanYan over 2 years ago
Hello, all
  I would like to achieve change property of parts in the scope of a whole design file.  Right now, I am able to use "findparts and setproperty" commands to change property within a selected sch page, but not in the scope of a whole design file.  Any ideas on how to possibly achieve it. Hope someone can shed some light on it. Would appreciate any help.
Yuan
  • CadAP
    +1 CadAP over 2 years ago
    set object [CapFindObjects $COrFindFilterDlg_PARTS {*}]
    You can replace * with the property value present on the components.It's return the DboPlacedInst. You can itearte over each DboPlacedInst. Please make sure that schemticView(any one page is open) is active.
    for example i am searching the property with Value "T4" and changing it value to "T3"
    set object [CapFindObjects $COrFindFilterDlg_PARTS {T4}]
    set lStatus [DboState]
    foreach item $object {
    set ItemId [$object GetId $lStatus ]
    SelectObjectById $ItemId
    SetProperty {TEST} {T3}
    SaveAll
    Hope this helps.
    • Vote Up +2 Vote Down
  • YuanYan
    0 YuanYan over 2 years ago in reply to CadAP
    It works and satisfies my need perfectly. Just one more question for understanding, I understand that COrFindFilterDlg_PARTS is a enum type of COrFindFilterDlg::QueryModeT, any description for other enum types can we find in any relevant document? (because I cannot find any further info for COrFindFilterDlg_PARTS in "TclTk extension" document). Hope you can point out to help. Thanks.
    Yuan
  • CadAP
    0 CadAP over 2 years ago in reply to YuanYan
    Hi Yuan,
    Glad to hear that command satisfy your requirement.
    Below are the ::QuerModeT, Similar to the object we select in "Find in"(Ctrl+F) command used in Capture schematic Editor:
    PARTS
    OFF_PAGE_CONNECTORS
    BOOKMARKS
    COMMENT_TEXT
    NETS
    FLATNETS
    HIER_PORTS
    DRCS
    TITLEBLOCKS
    POWER_SYMBOLS
    HIER_PINS
    PARTS_PINS
    VARIANTPARTS
    NETS_SINGLENODE
    DIFFERENTIAL_PAIR
    CLASS
    ELECTRICAL_CSET
    SPACING_CSET
    PHYSICAL_CSET
    MATCH_GROUP
