  2. Allegro X Capture CIS
  3. Some parts are missing on some pages in a schematic with...
  • Subscribers 44
  • Views 6110
Some parts are missing on some pages in a schematic with warning messages
soribom
soribom over 2 years ago
When I try to open an OrCAD reference schematic(.dsn) by AllegroOrCADSIPMCM FREE Physical Viewers 17.4,
Some parts('x' marks) are missing on some pages in a schemactic with warning messgaes as followings.
We've tried to downgrade the version of the schematic to OrCAD 16.6 and 16.2, but the same issues happens.
Could you let us know what cause this problem and how to fix this issue?
Thank you
Best regards,
Andy
  • VVRD
    0 VVRD over 2 years ago
    This message comes while reading pages and computing tool-generated net names. If due to some corruption, the same net name gets assigned to more than one net, then the above message is returned.
    If Capture detects this type of error on a page, it autocorrects the net connectivity by recomputing connectivity for that page and prints a message like the following:
    INFO(ORDBDLL-1191): Page PAGE* has database errors; autocorrection in progress. You might lose information.
    You will see '*' after the page name in Project Manager as it is not yet saved after the above operation. After you save the page and the design, this warning goes away and is not displayed on reopening the design. There should not be any loss of information in this case.
  • jongyann
    0 jongyann over 2 years ago in reply to VVRD
    Hello,I also encountered the same problem,
    After opening the Evaluation Board circuit diagram,
    "ordbdll-1191" message appears,
    I dare not press the save button,
    Because I am worried about overwriting the original file,
    Please help, thank you
