  2. Allegro X Capture CIS
  3. How to delete two line in BOM ?
  • State Verified Answer
  • Subscribers 43
  • Views 4952
kabalee
kabalee over 2 years ago
Hi Team,
i try to delete two line from BOM while generate from Capture CIS . i try to remove the two line and underline each time. is any solution for this ?
  • Akshay khosla
    +1 Akshay khosla over 2 years ago
    It seems you want to delete the below highlighted content, it is currently not possible in Capture Bom, you can try creating BOM using CIS BOM (if you have CIS license) by Reports> CIS BOM> Standard.
