  2. Allegro X Capture CIS
  3. How to create a library part from an existing design
  • Subscribers 42
  • Views 7486
yugandhar
yugandhar over 2 years ago
Capture provides a functionality to create a part (OLB) from an existing schematic.
When you use the Generate Part command to do this, Capture creates a library
file (.OLB) and a part based on the pins defined in the schematic. The library file (.OLB)
contains the new part and a copy of the schematic for easy portability and design reuse.
The Generate Part option is available under the Tools menu.
Hope all of you have been using this feature.
Yugandhar.
