  2. Allegro X Capture CIS
  3. Synchronization between CIS database, schematic design and...
  • Subscribers 45
  • Views 7259
Synchronization between CIS database, schematic design and layout footprints
SOT23
SOT23 over 2 years ago
We are currently using a CIS database (managed using a PLM software), Capture with CIS, and OrCAD PCB Editor Pro ; 17.4 S035.
We would like to find a way to synchronize a schematic design to the CIS database and to check whether the footprints used on the layout are the latest in the library.
Let's say we are designing a schematic, we use a component from the CIS database called PN001 rev 1.0. The netlist is generated and sent to the PCB editor. During the design phase, someone working on another project finds out that there is a problem with PN001's footprint. He updates it, not knowing that someone else is working on another project using the same CIS part. PN001 now has a new revision, PN001 rev 1.1, with a new footprint design (using the same name as the previous one).
Currently, when working on a schematic design, we have no way of knowing whether the CIS parts used are the latest in the database or not, the only way is to manually check each CIS part in the PLM to be sure it is the same as the one in the design ; that is not practical at all.
On the layout side, we cannot know if the footprints currently on the design are the latest in the library without updating every symbol on the board, which again, is not practical at all.
Is there a way to check, in Capture, that the database part revision used in the schematic is the latest in the database ?
Is there a way to check, in PCB Editor, that the footprint file being used in the layout is the latest in the footprint library ?
Thank you
  • revida marcos
    0 revida marcos over 2 years ago
    Your current setup does not appear to provide an automated means of checking whether CIS parts used in schematic designs and footprints used on layouts are up-to-date in their databases or libraries, necessitating manual checks which is neither time nor resource efficient.
    To address this problem, consider exploring:
    Integration With PLM: Search for ways to integrate your CIS database and PLM software more closely, providing automatic synchroniziation of schematic design data within CIS databases as well as real-time updates on part revisions.
    Design Rule Checks (DRC): Utilizing DRC rules within PCB Editor can assist in verifying whether footprints used in your layout match the latest versions in the footprint library, helping identify any discrepancies that need updating based on DRC checks and alerting you of them if needed. DRC checks can identify inconsistencies immediately so as to alert any necessary updates of footprints if required.
    Version Control: When designing with CIS parts and footprints, consider adopting a version control system to keep track of revisions and ensure all stakeholders use the latest versions. By doing so, version control makes it easy to spot outdated parts/footprints within your design and quickly identify their presence in an instant.
    Automated Notifications or Alerts in PLM Software: With automated notifications or alerts set up in your PLM software, designers will quickly be informed when there is a revision available of CIS parts or footprints and be given time to make decisions accordingly. This enables designers to be quickly alerted of updates so they can take immediate actions as required.
    Explore these options to simplify synchronizing between CIS database, schematic design and footprint layout; this makes the synchronization process more efficient while decreasing chances of using outdated components or footprints.
    thanks and regards
    revida marcos
  • SOT23
    0 SOT23 over 2 years ago in reply to revida marcos
    Hello and thank you for taking the time to answer.
    Maybe I don't understand correctly but to me the problem comes from Capture, not the PLM. We would need to do the synchronization test from Capture, as the database itself is not really linked to Capture, from what I know it is just a database file. The PLM software is writing in this database, and Capture reads it.
    I didn't knew DRC could do that ! I am going to dive deeper in the schematic DRC then. From what I know, engineers here don't use schematic DRC that much... They probably should though. If you have any resources explaining how to do that using DRC, I would be happy to read it !
    Do you have any version control software to recommend that works well with Cadence ? Steve pointed to OrCAD EDM that seems to do that.
    There is some kind of system like that already in place with the PLM, but there is so much engineers and so much component revisions all the time that nobody really use it. But maybe we could program something to only notify when a relevant part is being revised.
    Thanks a lot for the detailed answer !
  • SOT23
