  2. Allegro X Capture CIS
  3. How to create custom title block in OrCAD Capture CIS?
  • Subscribers 42
  • Views 9748
yugandhar
yugandhar over 2 years ago
Title blocks play a crucial role in creating schematic designs to represent the design name, version, organization, and so on. In Capture, the title block is customizable with all required properties with the desired shape of your choice.
Open the library in which you want to create the title block and select Design > New Symbol > Title Block.
The new title block window opens where you can assign all desired properties and create the required shape.
Now, you can browse this custom-created title block and place it in your designs by setting the title block as the default by using Options > Design Template > Title Block.
Browse the library location and select the desired name. This custom title block will be placed in every new design.
Yugandhar.
  • PatEscher
    0 PatEscher over 1 year ago
    Thats good explanation.
    But how do we handle variant specific properties in the title block. The only variant specific parameter we could use is the variant name.
    It seems that it is not possible to have other parameters being variant specific like a customer property I put on my title block. as soon as we switch into variant View, the props are read-only.
    Any idea if this is possible with the tcl API?
  • CadAP
    0 CadAP over 1 year ago in reply to PatEscher
    Hi PatEscher,
    Please check below tcl code it might provide you information you are looking for.
    #By running this script you can assign different Values for the properties present in the Title Block whenever we enter in the Variant mode. This script shows how .
    proc VariantPropSetEnabler {args} {
        return true
    proc VariantPropTitleBlockSetCallBack { Object } {
      set lPropNameDoc [DboTclHelper_sMakeCString {Doc}]
      set lPropNameRevDoc [DboTclHelper_sMakeCString {RevCode}]
      set lActiveVariant [GetActiveVariant]
    #Change the Variant Name as per your Variant present in the design. In the script Var1 is the Variant Name.    
      if {$lActiveVariant=="Var1"} {
    #If the variant mode is activated to Var1 the Doc and RevCode properties will get the values which are defined in the script.  
        set lPropValue [DboTclHelper_sMakeCString "Rev1"]
        $Object AddVariantProp $lPropNameRevDoc $lPropValue
    # Here we have defined the value of RevCode as Rev1.
        set lPropValue [DboTclHelper_sMakeCString "Doc1"]
        $Object AddVariantProp $lPropNameDoc $lPropValue
    #Here we have defined the value of the Doc as Doc1.    
    #Another Variant is defined i.e. Var2  
      if {$lActiveVariant=="Var2"} {
        set lPropValue [DboTclHelper_sMakeCString "Rev2"]
        set lPropValue [DboTclHelper_sMakeCString "Doc2"]
    RegisterAction "_cdnOrVariantViewSetTitleBlockProp" "VariantPropSetEnabler" "" "VariantPropTitleBlockSetCallBack" ""
