  2. Allegro X Capture CIS
  3. how add custom menu callback with OrCAD_Capture.xml or capTCLMenu...
  • State Verified Answer
  • Subscribers 43
  • Views 5800
how add custom menu callback with OrCAD_Capture.xml or capTCLMenu.tcl?
kwxsp86
kwxsp86 over 2 years ago
1. use "InsertXMLMenu" to add a custom menu, but cannot utf-8 encoding.
InsertXMLMenu [list [list "myfile1"] "" "" [list "popup" [encoding convertto utf-8 "中文"] "" "" "" "" "" ""] ""]
menu cannot show "中文"
InsertXMLMenu [list [list "myfile1"] "" "" [list "popup" "中文" "" "" "" "" "" ""] ""]
this command also cannot work(cannot show exactly),
2. use static method OrCAD_Capture.xml
succes show "中文"
but i don't know how connect the callback function?
thanks.
  • CadAP
    0 CadAP over 2 years ago
    Hi kwxsp86,
    Please use the below code and  make changes according to your requirements.
    namespace eval ::testMenu {
    proc registerMenuActions { args } {
    catch {
    InsertXMLMenu [list [list "MyFile1"] "" "" [list "popup" "MyFileTest1" "" "" "" "" ""] ""]
    InsertXMLMenu [list [list "MyFile1" "MyFileLevelpopup1" ""] "" "" [list "action" "MyFileTest1 &Level1" "0" "ActioForMenu1" "UpdateForMenu1" "" "" "" "This is my menu test2"] ""]
    InsertXMLMenu [list [list "MyFile1" "MyFileLevelpopup3" ""] "" "" [list "action" "MyFileTest1 &Level2" "0" "ActioForMenu2" "UpdateForMenu1" "" "" "" "This is my menu test2"] ""]
    InsertXMLMenu [list [list "MyFile1" "MyFileLevelpopup3" ""] "" "" [list "action" "MyFileTest1 &Level3" "0" "ActioForMenu1" "UpdateForMenu1" "" "" "" "This is my menu test2"] ""]
    RegisterAction "ActioForMenu1" "::testMenu::shouldProcess" "" "::testMenu::testActionProc1" ""
    RegisterAction "UpdateForMenu1" "::testMenu::shouldProcess" "" "::testMenu::testUpdateProc1" ""
    RegisterAction "ActioForMenu2" "::testMenu::shouldProcess" "" "::testMenu::testActionProc2" ""
    RegisterAction "UpdateForMenu2" "::testMenu::shouldProcess" "" "::testMenu::testUpdateProc2" ""
    proc shouldProcess { args } {
    return 1
    proc testActionProc1 { args } {
    puts "Got in testActionProc1!"
    proc testActionProc3 { args } {
    proc testUpdateProc1 { args } {
    return true;
    proc testActionProc2 { args } {
    puts "Got in testActionProc2!"
    proc testUpdateProc2 { args } {
    return true;
    ::testMenu::registerMenuActions
    Hope this help!
  • kwxsp86
    0 kwxsp86 over 2 years ago in reply to CadAP
    yes, i have got this sample before. but, when i use chinese(eg. "中文") as the label, the ui menu shows "??????".  i have try lots of encodings, but not works.
  • kwxsp86
    +1 kwxsp86 over 2 years ago in reply to CadAP
    https://community.cadence.com/cadence_blogs_8/b/pcb/posts/what-39-s-good-about-capture-s-customization-capabilities-16-6-has-several-new-enhancements
    this blog show a static methord, but i donot know how and where connect my own menu callbak function.
  • kwxsp86
    0 kwxsp86 over 2 years ago in reply to kwxsp86
    @Jerry GenPart
  • kwxsp86
    spb version 16.6 there's no problem about oem encoding(insertxmlmenu oemcodingpage string, work good), but at version  17.2, the interface insertxmlmenu, do a step more with "encoding convertfrom cp936 $cp936string"
    any help?
