  2. Design Entry HDL
  3. How to reuse the hierarchical block?
  • State Verified Answer
  • Replies 8
  • Subscribers 25
  • Views 24777
ChristopherG
ChristopherG over 17 years ago
Hello, everyone.
I am now learning the CAPTURE's complex hierarchical design structure and I am using the software version 9.1. I am now encoutering a confusing problem. My problem is same as the author of the theme:www.chronology.com/.../ShowPost.aspx
  That is I want to reuse the descend schematic of a hierarchical block(suppose named A) many times, because there are many similar circuit blocks in my design. Firstly I creat a hierarchical block named A and complete the descend shematic of it. But when I make a copy of the hierarchical block A, I find that the reference designator of all the components in the descend schematic are the same between the copy and A. And when I change the componet reference in the descend schematic of either A or the copy, the other change at the same time. This makes the problem that A and its copy refers to the same circuit block but not two similiar one.
  I have read the help files of the software very clearly, but can't get the answer.
Wishing for your reply.Thank you.
  • oldmouldy
    oldmouldy over 17 years ago +1 verified
    If you have more than one copy of a hierarchical block in a design, the design is called a "complex hierarchy", the design will have changed to "Occurrences" mode and the annotation will be stored in the…
  • ChristopherG
    ChristopherG over 17 years ago +1
    oldmouldy said: If you have more than one copy of a hierarchical block in a design, the design is called a "complex hierarchy", the design will have changed to "Occurrences" mode and the annotation will…
  • Wild
    0 Wild over 13 years ago
     Hosting site went down, try this link:
    http://freepdfhosting.com/38e7c5b27f.pdf
  • iampaulq
    0 iampaulq over 7 years ago in reply to Wild
    Hi, I know this is an old thread, but can i get a copy of this tutorial of possible...Thanks.
  • Medet
    0 Medet over 5 years ago in reply to ChristopherG
    Your question and solution for this issue helped me even in 2021 year, thanks a lot :)
