  3. PTF File Utiligation
  • Subscribers 163
  • Views 13892
archive over 17 years ago
Hello Everybody
     Using PTF file I can add Properties to cells only.I want to set These properties as default to
the entire library how can i do this. My main problem is i need to create Resistor symbols for each and every value,for each and every value of resistors i need to add our Customized propeties.
Give me a sollution.
Thank in Advance
N Raghuram
    One of the main values of the PTF file is to have one generic schematic symbol, then use the PTF file have many possibilities for that symbol. Generating a unique resistor symbol for each and every resistor makes a lot of overhead and really makes using a PTF file a waste of time.
    Why can't you use a single resistor symbol and use the PTF to select the actual physical resistor?
