  3. Adding function key for color -toggle command in env fi...
  • Views 926
Adding function key for color -toggle command in env file
archive over 17 years ago
I had added a shortcut key for the command color -toggle "Package Geometry/silkscreen_top" in my enviornment file as below.
 funckey h color -toggle "Package Geometry/silkscreen_top"
But I am getting the error "Invalid class specified: PACKAGE" while I press key 'h' from Allegro window. But the same command works fine when I copy and paste it in the allegro cammand input window.
It will be very helpful if any of you can clarify this behavior.
Thanks in advance
  • jhorner
    jhorner over 17 years ago
    The quotes are getting swallowed, so you need to do it as such:
    funckey h 'color -toggle "Package Geometry/silkscreen_top"'
           single quote                                                    double quote followed by single quote
     Hello John,
    Thank you very much for your input. I got it working now :)
