  3. spice model question
  • Replies 9
  • Subscribers 168
  • Views 16911
fongcj
fongcj over 17 years ago
I'm trying to simulate a circuit that has an infineon bfr750 in it. My libraries do not contain it and all I'm given from the the infineon website is a .CIR file and a set of .S2P file. How do I create this part with the parameters I was given?
  • vokaraca
    vokaraca over 17 years ago
     Thanks a lot. Now, we can use part at cir format.
     Best Regards.
  • laboredm
    laboredm over 16 years ago
    I'm trying to run a simulation in Capture CIS but the net list is giving me this error
    WARNING [NET0093] No PSpiceTemplate for D1, ignoring
    WARNING [NET0093] No PSpiceTemplate for D2, ignoring
    They are there.  I have been to the pspice model editor and everything seems to be there.  I'm using the one for di.lib.  I need some help.
    Thanks.
  • tliky
    tliky over 15 years ago
    I have a similar problem for ad8221, I had teh .cir and the .olb file. I did what you said on Pspice, but there were still error, mainly floating point... but I check it over and overe agin.... I dont know what I did wrong.
  • Kondor
    Kondor over 15 years ago
    The diodes that you use do not have a Pspice template or model. When you use a diode, in the parts window ( when you select the part ) look in the low right corner where you see the design of the part and under the image you will see, or not ( depending on the component ) 2 small pictures representing PSpice and Layout. Make sure that the component that you use has the Pspice picture under it and the error will not appear anymore. Good luck!
