  3. Help with how to transfer a user defined property in orcad...
  • Replies 9
  • Subscribers 166
  • Views 18624
Help with how to transfer a user defined property in orcad capture to PCB editor
JasonW
JasonW over 16 years ago
I have test points in capture where I want to display a specific name on the board.  For example, lets say for TP1, I want a silkscreen name called MasterSupply to show up on the board instead of TP1.  At first I thought I'd just rename the refdes from TP1 to MasterSupply in capture.  Unfortunately when I annotate it changes it to MasterSupply1.  I couldn't figure out how to stop it from annotating that particular part easily so I thought I'd create a user property called SSNAME (silk screen name) and import that property into PCB editor.
 I've read through some of the documentation on how to bring in user defined properties, such as opening up the contraint manager and adding a new column called SSNAME in the component properties with a string property.  Now I thought that's all I needed, but when I netlist the board into PCB editor, the SSNAME value does not transfer.
 What am I missing?
Jason
  • oldmouldy
    oldmouldy over 16 years ago
    The easiest way to achieve this is to use "BCE", "DGS" and so on as the Pin Numbers in both the Schematic and Footprint symbols. Although not strictly numeric, legal pin numbers include A-Z and 0-9 to accommodate BGA pin numbering.
  • tltoth
    tltoth over 16 years ago
    redwire,
    I know how to map a user defined property to a layer in pcb editor, but how do you map it to a symbol iwhen you edit one?
    From where will the symbol know what my property is?
    Lajos
  • John Davies
    John Davies over 16 years ago
    Thank you all for the suggestions - I now have many methods to choose! To my embarrassment, my immediate problem was that I had forgotten to select the checkbox for Allow User Defined Property in the netlister tab. Oops... I wondered why I couldn't find the property in PCB Editor.
    I still find it curious that the Name of a pin is not transferred automatically because this is the easiest way of showing the function of each pin of a connector. It would be simpler to make custom footprints for transistors where the function is fixed - good idea.
  • redwire
    redwire over 16 years ago
    tltoth said:
    I know how to map a user defined property to a layer in pcb editor, but how do you map it to a symbol iwhen you edit one?  From where will the symbol know what my property is?
    Not sure that that's possible here.  You can attach the property to a component but it does not push into the symbol which is the physical description of the component.  The property can be generically mapped to the package geometry layer.  Perhaps others can comment.
