  3. Adding dynamic shape violates DRC rules
  • Replies 8
  • Views 16129
mvonahnen
mvonahnen over 17 years ago
 For some reason,  a setting has changed which now causes added dynamic shapes to create DRC errors.  I have 32 shapes that don't violate the rules, but I added one to the bottom, with exactly the same parameters and it cause 70+ DRC errors.
  • mvonahnen
     It is not a consistent problem.  But to answer your questions:
     1.  I did this first to create the shape initially.  Twice as many DRCs on the solid shape as with the cross hatched one.
    2.  GND (ground)
    3.  I did not do this and I had to move on, so I created voids where the tool was creating DRC errors.
    I have run into this many times with other tools, Altium was my previous tool.  I am just surprised to see it in Allegro.
  • redwire
    redwire over 17 years ago
    Without seeing the DRC report it's hard to tell what's going on.
    If you're willing to post up the design or PM it I can take a look but there should be NO issue.
    I would try Cadence support as well.
  • CubbyBear
    CubbyBear over 16 years ago
     Late reply but I noticed this happened to me just yesterday. I was getting DRC errors on dynamic shapes. How the heck? Anyway, I found it was because I had "rough" shapes selected. When I changed the setting to "smooth", all the DRC flags went away.
    CB
