  3. Shape disappering after changing constraints
  • Replies 8
  • Subscribers 166
  • Views 16625
mvonahnen
mvonahnen over 17 years ago
 I updated some clearance constraints, which caused all of my dyanmic shapes to be out of date.  When I did an update, one of my shapes would not update.  I can not select it, it does not show up.  I thought that the shape must have been deleted, but when I replaced it, the new one also disappeared and would not update.  Whats going on?
  • redwire
    redwire over 17 years ago
     Have you tried his suggestion of setting the boundary color (only) on and picking the shape?
    You can easily move the shape off board, change its dynamic characteristics, delete it, whatever.
    But as said, it's difficult to solve by chance.  You can post boards to this forum (users, free, you get what you pay for) or the Cadence help via sourcelink.
  • Ejlersen
    Ejlersen over 17 years ago
    First try doing tools, quick reports, shape report and look for any no etch shapes
    Then click the coordinate for this shape and the screen will center around it.
    Turn on boundary elements and walk along those until you find something that could cause this problem.
    You could also just do a move, select the shape and write ix 0 0 in the command promt to move it 0 in both the x and y direction (same as not moving it)
    Hope this helps,
    Ole
  • bulldog
    bulldog over 17 years ago
    We had this happen also with the shape on the top etch layer.  What seemed to work was changing the individual shape line/cline clearance to be .0001, an extremely small amount over our desired global clearance of 20 mils.  There appears to be a problem with the shape fills in version 16.01.
