  3. Allegro 16.0
  • Views 13498
Allegro 16.0
hcowles
hcowles over 17 years ago
Just started using Allegro PCB Design XL version 16.01
where do I reset the graphics or user preferences to stop the pads, vias and traces from highlighting and identifying the element?
 thanks in advance
  • lcanx2
    lcanx2 over 17 years ago
    Although I don’t, to disable data tips in 16.1
    Setup->User Preferences…
    Preselection
    Disable_datatips
  • hcowles
    thanks
    that will disable the popup that displays what the elements that are highlighted.
    is there a way to stop the highlighting as the mouse goes over the trace, pads or vias
  • oldmouldy
    oldmouldy over 17 years ago
    You can set the Find Filter to "All Off" but this will spanner attempting to pick "stuff" with the mouse left-click (or pre-select mode), you would then need to use the menus and set the FInd Filter for each operation like the pre-16.0 way of working, or set the Find Filter for each operation before pre-selection. (If you are over a bunch of "stuff", the tab key will cycle through the objects to get the required one)
  • hcowles
    thanks
    that does what I was looking to do
