  3. Translating Pads footprints into allegro
  • Subscribers 163
  • Views 17906
CircuitBoy1
CircuitBoy1 over 17 years ago
 I'm having trouble to import pads footprints into allegro.. So far I understand the pads_in.ini has to be located where the ascii file is to be translated...But i've also read that you have to add lines to that so allegro can map the layers properly..what are the lines that I have to add?.. because all I get are errors when i try to import my ascii file.
  • CircuitBoy1
    Can you give me an example of the line I have to write in the ini file
