  3. Allegro Extra pins and Missing Pins
  • Replies 12
  • Subscribers 168
  • Views 25019
salasidis
salasidis over 16 years ago
I am new to Allegro, and have a problem with PCB Footprints for certain components.
For example,
A) one component mounts on a Dip16 footprint, but only has 4 pins (pin 1,8,9,16).
B) A diode uses a SOT-23 package with 3 pins, but only 2 pins are required.
How does one force Allegro to ignore missing pins in the schematic that are not required (example A).
I have "fixed" this by defining in my Orcad CIS part schematic invisible zero length pins that are not required (ie define the other 12 pins in example A, or create a new diode symbol with an extra unused pin.
Is there a better way?
(netrev.lst output below
ERROR(SPMHNI-196): Symbol 'SOT65P210X110-3N' for device 'DIODE TS_SOT65P210X110-3N_DISCR' has extra pin '3'.
#2   WARNING(SPMHNI-192): Device/Symbol check warning detected.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '2'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '3'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '4'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '5'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '6'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '7'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '9'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '11'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '12'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '13'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '14'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '15'.
  • redwire
    redwire over 16 years ago
    salasidis said:
    Thanks, but could you please tell me where to set the NC propery. I looked within Allegro 'Display' 'Property' but could not find an NC entry.
    I would think creating a new footprint with the NC= for the pins not used would be easiest
    I tried adding an NC property within the part properties of Capture, but this has not worked, I still get the same netrev.lst message (I tried it for the Dip16 part)
    Addendum: I managed to get the DIP16 to work with an NC parameter added to teh capture side (not sure why it did not work the first time).
     However if I try making a new footprint with a DIP16 layout but only 4 pins defined (1,8,10,16) to match the capture, I still get the error message about the missing pins. Do the PCB Footprint pins have to be in a linear order (ie no skipped numbers)
    Pins do NOT have to be linear order.  They can be random.  There has to be a 1:1 association from the schematic symbol and the footprint.
    You might check the OrCAD tutorials for this as well.
  • salasidis
    Both your statements are what I meant to say.
    The part has 4 pins (in the corners, except that pin 10 is used instead of pin 9 in a DIP16 layout).
    The schematic of the company lists the [part with 4 pins, but the numbers are 1,8,10,16  (ie not sequentially numbered)
    I managed to get the part to load into Allegro with no errors using the NC-2,3,4 etc as suggested by others earlier.
    However, if I were to go into DIP16, erase 12 of the pads, but keep the ones remaining with their original part numbers (ie not sequential) it seems to fail whether NC is specified or not.
    I woud assume that sequential pin numbring is therefore required, but it makes using the schematic, and correlating it with the actuial datasheet a little more cumbersome.
  • steve
    steve over 16 years ago
    Just make sure your schematic symbol and PCB Footprint match exactly. If you want 4 pins numbered 1,9,10,16 on the footprint, make sure the schematic symbol matches, i.e has pins 1,9,10 and 16. They do not have to be sequential they just have to match.
  • redwire
    Here's a working example.  I took a 4 pin oscillator and mapped it to a standard 16 pin footprint.  Prior to adding the NC property I got the same errors as you.  Look at the oscillator in OrCAD and you will see the NC property that allows me to map it to a 16 pin part.
    ncexample.zip
  • Cadpro2K
    Cadpro2K over 16 years ago
    The "NC" property is added in Capture (schematic), not the layout.
    1) Pick the part on the schematic; RMB --> Edit Properties (Properties GUI comes up)
    2) Click New Column tab: Add NC as the Name and your pin numbers as the Value
    (e.g. New Column --> Name: NC ; Value: 1,2,3,etc. whatever pins are no connect)
    Good day.
    Mitch
