  3. Allegro Extra pins and Missing Pins
  • Replies 12
  • Subscribers 168
  • Views 25021
salasidis
salasidis over 16 years ago
I am new to Allegro, and have a problem with PCB Footprints for certain components.
For example,
A) one component mounts on a Dip16 footprint, but only has 4 pins (pin 1,8,9,16).
B) A diode uses a SOT-23 package with 3 pins, but only 2 pins are required.
How does one force Allegro to ignore missing pins in the schematic that are not required (example A).
I have "fixed" this by defining in my Orcad CIS part schematic invisible zero length pins that are not required (ie define the other 12 pins in example A, or create a new diode symbol with an extra unused pin.
Is there a better way?
(netrev.lst output below
ERROR(SPMHNI-196): Symbol 'SOT65P210X110-3N' for device 'DIODE TS_SOT65P210X110-3N_DISCR' has extra pin '3'.
#2   WARNING(SPMHNI-192): Device/Symbol check warning detected.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '2'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '3'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '4'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '5'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '6'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '7'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '9'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '11'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '12'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '13'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '14'.
ERROR(SPMHNI-196): Symbol 'DIP16' for device 'CPC1945G_DIP16_DISCRETE_CPC1945' has extra pin '15'.
  • aneter
    aneter over 14 years ago
    to everybody..... when you create the netlist in Orcad you have to include the option "allow user define proprieties" otherwise the NC propriety is ignored by allegro
  • redwire
    redwire over 14 years ago
     Never had to do that.  I think you might be doing something wrong.
