  3. Drill Legend exceeding the page size
  • Replies 11
  • Subscribers 166
  • Views 18844
girish
girish over 16 years ago
Hi Good Day to ALL! Please find the attached screen shot . drill legend exceeding the page size (page size is D).Is ther any way to control the legend so that I can split the chart in to two coloumns. Regards, Girish Kumar
  • girish
    Thanks for your suggestion ! But I am unbale find this setting .Could you pls show me the menu path it will really helps. Regards, Girish Kumar
  • aruprecht1
    aruprecht1 over 16 years ago
    This is the default path name for Allegro on my system
    \Cadence\SPB_16.01\share\pcb\text\nclegend\default-mm.dlt
    But we created a special .dlt file with different options than Allegro's that is keep in
    \Info_Processes\Pwb\Scripts\default-mm_co.dlt
  • girish
    I got it !!!!! Thanks all for the help in solving .(pls find the modified chart ) Regards, Girish Kumar Bangalore
  • Markos03
    Markos03 over 15 years ago
    hi all
    what if we have different figure sizes in our design for different drill holes, how would we adjust every row height in the drill legend table to compensate with the figure sizes. so that we will not have a fixed row sizes. is there a way to adjust the individual row hieghts in the ncdrill legend table? i would appreciate ur replies.
     -Markos-
  • mcatramb91
    mcatramb91 over 15 years ago
    The Row height is driven by the largest drill figure size and all the rows will be at that consistent height.  The only option you have is to modify the drill template file (.dlt) so all the drill figure sizes in the drill legend table are the same.
    The parameter you will need to update inside the .dlt file is called " ?FixedFigureHeight", it defaults to " ?FixedFigureHeight    0" and any number other than zero will be the actual height of the drill figure in the drill legend table. (Note: This change only effects the drill legend table)
    This may not be what you are looking for but as far as I know there is no way to individually adjust the row heights in the drill legend table as they all come out at a consistent height.
    Hope this helps,
    Mike Catrambone
    Plexus Technology Group
