  3. Allegro PCB Editor Report like Condensed BOM report
  • Replies 40
  • Subscribers 167
  • Views 45060
ahmetozsoy
ahmetozsoy over 16 years ago
Allegro Editor ( 16.2)  generates Bill of Material Report(Condensed). The report columns are SYM_NAME,COMP_DEVICE_TYPE,COMP_VALUE,COMP_TOL,COMP_CLASS, QUANTITY and REFDES.
This simplified report gives the quantities and used component REFDES in same line.
For ex.
SYM_NAME   COMP_DEVICE_TYPE        COMP_VALUE .... REFDES
0402               CAP_SMD-GRM155R71C103KA88D-0402,10NF_50V,GRM155R71C103KA88D        10NF_50V    .....   C3,C5.....
What I want to do is to genarate a report like this simplified one but with PART_NUMBER not COMP_DEVICE_TYPE. Because COMP_DEVICE_TYPE is always long and does inculde extra information other than PART_NUMBER, I wish to use only the PART_NUMBER intsead of COMP_DEVICE_TYPE.
I have checked every option and could not find a simplified report like this one. QUANTITY doesn't exist in generating reports. I want to see the quantity in one line only. So my report can be like this
SYM_NAME   PART_NUMBER                    COMP_VALUE .... REFDES
0402               GRM155R71C103KA88D        10NF_50V    .....   C3,C5.....
Thank you for your helps.
Ahmet OZSOY
  • oldmouldy
    oldmouldy over 11 years ago
    There is something amiss with the RefDes text formatting, it could be "just blank", in any case, do you have an example BRD file that you can attach so that I can test the code?
  • chads108
    chads108 over 11 years ago
    Can you give me an address to send you a file, or contact me privately at csaathoff@iphase.com.  The file is too big to attach.
  • chads108
    Oldmouldy,
    I spent a little time trying to figure out why this wouldn't work for me.  I decided to try it on another board file and it ran perfectly, so i narrowed it down to something board specific.  I noticed that on the board file that it wouldn't run, there was a reference designator that was in the format of: P6A  That is what proved to be the problem with the script running.  Once I removed that, it ran as expected.  Now the question is, can the SKILL script take that in to account, or does it overly complicate the entire request.  I suspect this is a rare occurrence so maybe not worth the effort.
    Thanks for your input and help.
  • oldmouldy
    Hi Chad, OK I suspected something like that might be the case. To sort the RefDes list, the assumed format is (bunch of letters) then (bunch of numbers), like C54, TR629 and so on, the code "chucks up" when the trailing letter gets encountered and the resulting value is then empty, hence the message about "requires 'something' is nil". I will modify some RefDes's on a test board and see if I can get the code to be more tolerant of the RefDes format.
  • oldmouldy
    2867.cond_bom.zip
    It looks like a standard axl function will help out with the sort.
    Also includes Value, comment out the lines that output the value, where indicated and un comment the lines that don't output the value.
    sample test report output in archive
