  3. special pad shape creation
  • Replies 7
  • Views 17383
stellar
stellar over 16 years ago
I've created a pad shape in Autocad and then imported the dxf file into a new symbol drawing. I'm mapping the dxf to ETCH/TOP but when it comes in it doesn't act like a filled shape nor can I create a symbol from the imported drawing. I get errors in the log file complaining about clines and other things when I try to create the symbol.
  • oscar migs
    oscar migs over 16 years ago
    stellar,
    It sounds like the shape was created using lines.
    The shape must be created as a closed polyline.
     Best of luck,
     -oscar
  • Nagaraj Shanmu
    Nagaraj Shanmu over 16 years ago
    you can try menu shape-->compose shape option to convert the lines to shape
    Good luck!!
    ~Nagaraj.
  • Romme
    Romme over 16 years ago
    First You should do a new shape not a new symbol drawing, sorry if i misunderstood. Second import from dxf only the outline and compose the shape from that.
  • purikku22
    purikku22 over 16 years ago
    Hi, if i may suggest, you could directly make special pad in allegro and use it in pad designer to create the .pad file. just create shape symbol (.ssm file) then in pad designer there is a shape category and browse the .ssm file you created
    Good day.
  • stellar
    Getting closer with this. I was using Alibre to create the DXF and that appears to be a problem. I created the DXF in Autocad as a Polyline and that works now and I can create the ssm file. Now over in the pad designer I choose this as my shape and do a check on it and it says there are no errors. When I try to save it though it says "Pad stack origin outside all pads". I tried moving the origin in Autocad to a point on the shape but that didn't fix it.
