  3. dynamic shape not updating
  • Replies 21
  • Subscribers 172
  • Views 29300
Tanveer
Tanveer over 15 years ago
I have a problem with dynamic shape on my board.
dynamic shapes on the board not updating even they are not voiding from any where. shape fill type is smooth and I try to update it from Display>Status>update dynamic shapes but error msg occured
"1 dynamic shape is still out of date or empty.  Run Out of date shapes Report from status dialog to identify them."
I also try to DB doctor my pcb but not working. In the starting shape was fine Error occured suddenly I didnt know how it happens.
previously I have this problem and I resolved it by chance by removing internal plane layers from Xsection and again defined them. but I know this is not a proper solution.
Any Suggestions.
Regards
Tanveer
  • komikumi
    komikumi over 14 years ago
    Dear andri26,
    Thanks for your help.
    I could see all fault shapes.
    Best Regards.
  • Cadpro2K
    Cadpro2K over 14 years ago
     My process is usually:
    1) Play with Shape/Global Parameter setting, and see if it updates
    2) Tools/Database Check - 1st 2 boxes selected
    3) Move the shape off the board; move it back on.
    I know it might sound clunky, but 1 of the 3 always works.
  • edhickey
    edhickey over 14 years ago
    turn on the boundary class to see the "hidden" shape. Open color dialog - stackup folder ....
  • Yoda5939
    Yoda5939 over 11 years ago
    Steve,
    I have this problem after updating shapes. I followed your directions and was upset because that didn't work. I then read your messge carefully. I didn't know the buttons were interactive. I've been using this tool for quite some time and didn't know this. Thanks!!
    Ron Scott
  • Amyamy
    Amyamy over 10 years ago
    Thank you so much.
