  3. Swapping layers in Allegro PCB
  • Replies 8
  • Views 26349
mvonahnen
mvonahnen over 16 years ago
 Is there a way of moving the layers in the cross section setup?  I tried copying all the objects to a new layer, but a have a mix of plane and route components and it looses the net connections when it does the copy.
 I just want to change the order of the layers.
  • ConnectPCB
    ConnectPCB over 13 years ago
    Is there existing skill code that would accomplish layer moves ?
  • mcatramb91
    mcatramb91 over 13 years ago
    I have used a Sub-Drawing (File > Export > Sub-Drawing) in the past to perform the swapping of layers instead of using Edit > Change.
    1) File > Export > Sub-Drawing
    2) Turn on the Clines/Shapes for the two layers you wish to swap
    3) Set the Find tab to Clines/Shapes only and check all Preserve options, except Preserve Refdes, under the Options Tab
    4) Window the entire board and select 0,0 as your clipboard origin point
    5) Edit the clipboard file (.clp) created in the previous step and swap the layers names
    6) Delete all the Cline/Shapes on the two layers you turned on in Step 2
    7) File > Import > Sub-Drawing and use the 0,0 as your load point (match origin point selected in Step 4)
    That's it.  Maybe it will correct the issue you are seeing.
    Hope this helps,
    Mike Catrambone
    Plexus Engineernig Solutions.
  • dalTools SKILL
    dalTools SKILL over 8 years ago in reply to ConnectPCB
    Yes!  dalTools has a simple GUI based layer tool where you simply move the layers around in the stack order and apply.  It takes care of all the associated other layers like keepouts, anti-etch and constraint values too.  This is one of over 100 useful utilities available.  Get a free 30 day license at www.daltools.com
