  3. Unable to backannotate, need help
  • Replies 7
  • Subscribers 166
  • Views 15864
DanielAmir
DanielAmir over 15 years ago
Greetings,
 I am experiencing a problem while I am trying to backannotate the swapped pins to the schematic. It keeps complaining:
"Unable to backannotate the changes to design file "\ABCD\.DSN" because the original design file used to create the board has a different name "ABCD.DSN". Choose the correct design file and backannotate again."
But I have used the same file to create the PCB and I don't have  any idea where those "\"s are comming from. Does any one have any idea?
Daniel
  • sprayaga
    sprayaga over 6 years ago
    in my case i have the same file name, havent changed anything but i get the same error pop up. Did your issue get resolved. Any suggestions would be appreciated
  • luvishis
    luvishis over 6 years ago in reply to sprayaga
    Suggestion : create empty directory, put there ONLY your design file (DSN file), rename to T.DSN, extract  Allegro PCB netlist, import into the board and then try to backannotate.
