  3. Copper over footprint pins
  • Replies 8
  • Subscribers 166
  • Views 18215
Olek
Olek over 15 years ago
I use Allegro/OrCAD PCB Editor for pcb design.
I have problems with irregularly shaped pins.
“Shapes” not always can be used to define padstack for such pins.
In such cases I have to add copper over the pins.
Example:
Vishay POWERPAK-1212-8 footprint requires exposed copper that overlaps partially two pins.
I would like to show 8 pins on the schematic part, so the footprint must have the same 8 pins.
I have added copper (etch) partially overlapping these pins.
I got DRC errors.
After I placed symbol on the board the DRC errors remained.
The question is: How to get rid of these errors?Can I do something with the copper to get rid of errors, or maybe I can turn off DRCs for the specific pins (or copper) on board level. Another example when I can't use "Shapes": Padstack pad that are “C” shaped with the pin origin located outside the shape (beyond the copper).
I think that routing to such pin will be impossible.
  • redwire
    redwire over 15 years ago
     You've got several "mixed" solutions here... all will probably work.
    But to answer the question you directed at me -- a shape/pin violation will go away when netlisted.  You need to be aware of shape-shape clearance rules that have to be met.
    Or -- add the shape/paste to the board after you've placed the part -- your choice.
  • redwire
     Here is a zip file with a part I made up with two copper shapes... one shorts across pins 7&8 and the other across 5&6
    In the board file with _no_nl (no netlist) you see there are DRC errors with the pins touching the shape.
    In the other board I attached a netlist to short the pins and the DRC errors go away.
    Hope that helps.
    shorted_pins_demo.zip
  • Olek
    Thanks again,
    Olek
