  3. Package Symbol Update Path Help
  • Subscribers 166
  • Views 16553
UpNorth
UpNorth over 15 years ago
 Hi All,
    Looking for some serious help here, since this one has bafled me.
My .brd file will absolutly not update the symbols 'r0603', 'c0603' that I have in a local directory (T:\pa\boards\Cadence\AllegroPCBEditor\Package).
As you can see below by the lib_symbol_path report, the SYMBOL Library shows that these symbols are being pulled form the Cadence Lib - however I've edited the env variable to exclude the cadence libraries
i.e
SET PSMPATH = t:\pa\boards\Cadence\AllegroPCBEditor\Library\Package t:\pa\boards\Cadence\AllegroPCBEditor\Library\Mehanical t:\pa\boards\Cadence\AllegroPCBEditor\Library\Format
Set PADPATH t:\pa\boards\Cadence\AllegroPCBEditor\Library\Padstack
I've run a quick echo in the command prompt to show you the results:
Command > echo $PSMPATH
T:\pa\boards\Cadence\AllegroPCBEditor\Library\Package T:\pa\boards\Cadence\AllegroPCBEditor\Library\Mechanical T:\pa\boards\Cadence\AllegroPCBEditor\Library\Format\
Command > echo $PADPATH
T:\pa\boards\Cadence\AllegroPCBEditor\Library\Padstack\ T:\pa\boards\Cadence\AllegroPCBEditor\Library\Padstack
I've gone through and whipped out the  C:/Cadence/SPB_16.0_share_pcb_lib\symbols\ directory just in case...still when I update the symbols in the .brd file, no change.
I've verified that my r/c0603 .dra and .psm symbols are updated to what I expect in my local directory - but still no luck.
I've look at the datestamp on the the .dra and .psm files, and they look good.
Any help would be much appreciated here. Hopefully one of you can show me what I seem to be doing wrong.
-UpNorth
Symbol Library Path Report
SYM_NAME SYM_LIBRARY_PATH SYM_TYPE
R2512 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/r2512.psm PACKAGE
L0603 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/l0603.psm PACKAGE
SC75_SOT416 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/sc75_sot416.psm PACKAGE
QFN10_TI_RSE T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/qfn10_ti_rse.psm PACKAGE
QFN8_TI_RSE T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/qfn8_ti_rse.psm PACKAGE
MOUNTHOLE_CIR_4_40 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/mounthole_cir_4_40.psm PACKAGE
TESTPOINT0603 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/testpoint0603.psm PACKAGE
HEADER1X3_2_54MM T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/header1x3_2_54mm.psm PACKAGE
SJ1_3515_SMT T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/sj1_3515_smt.psm PACKAGE
QTE_020_01_LDA T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/qte_020_01_lda.psm PACKAGE
TSSOP16_TI_PW T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/tssop16_ti_pw.psm PACKAGE
HEADER2X8_2_54MMPITCH T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/header2x8_2_54mmpitch.psm PACKAGE
DSUB09M T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/dsub09m.psm PACKAGE
USB_SMD_MICROAB T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/usb_smd_microab.psm PACKAGE
L0805 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/l0805.psm PACKAGE
SOT23_5_TI_DBV C:/Cadence/SPB_16.0/share/pcb/pcb_lib/symbols/sot23_5_ti_dbv.psm PACKAGE
D0603 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/d0603.psm PACKAGE
D1206 T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/d1206.psm PACKAGE
SWITCH_KMR221GLFS T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/switch_kmr221glfs.psm PACKAGE
SOT23_6_TI_DBV T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/sot23_6_ti_dbv.psm PACKAGE
C0603 C:/Cadence/SPB_16.0/share/pcb/pcb_lib/symbols/c0603.psm PACKAGE
SOT223_6_TI_DCQ T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/sot223_6_ti_dcq.psm PACKAGE
CRADIAL8_3MMX8_3MM T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/cradial8_3mmx8_3mm.psm PACKAGE
R0603 C:/Cadence/SPB_16.0/share/pcb/pcb_lib/symbols/r0603.psm PACKAGE
TSSOP8_TI_PW T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/tssop8_ti_pw.psm PACKAGE
FUSEHOLDER_5MM T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/fuseholder_5mm.psm PACKAGE
CUI_PJ_002A_SMT T:/pa/boards/Cadence/AllegroPCBEditor/Library/Package/cui_pj_002a_smt.psm PACKAGE
  • Panglossian
    Panglossian over 14 years ago
    Hey dave n all,
     Am a begginer in SKILL language..I need to group the package symbols under dfa list to subcategories...like.. if der is
    -C0402
    -R0402
    in the package symbol...dese two shud b categorized under 0402 folder...am workin on dis script of creatin a folder 0402 and categorizing dese two under d d same folder..can u help me wit dat..if u hav any doubt,most welcome...am breakin head wit dis for few weeks.. i dnt even knw hw to access the symbols in the list..wats d path for dose symbols..plz do help me..sorry for interruptin dis pots..i found it related ..so made apost..
    Thanks n regards,
    Panglossian
