  3. Purpose of Tooling Corners?
  • Subscribers 163
  • Views 13777
mjmessinger
mjmessinger over 15 years ago
Hi Everyone,
We have some older boards that contain tooling corners.  On these boards, they are placed at the corners (of course) and spaced slightly outside the board outline.  Previous vendors have ignored them while another is using them to define the board extents.
Can anybody tell me: 1) What is the purpose of the tooling corner, and 2) where should they be placed if they are used?
Thanks for any help on the subject.
Matt M.
  • redwire
    redwire over 15 years ago
     They used to be added for film alignment at the fabricator -- never for board extents.  Should be harmless to keep.  Always check with your fabricator first however.
  • Mashak
    Mashak over 15 years ago
     As informed by Redwire they are used for film alignment by the fabricators , If your board has a extra frame then you can add the tooling holes on them or else you can define your existing mounting holes inside the board geometry as tooling  holes in the Fab notes.
