  3. Via masking
  • Subscribers 163
  • Views 13470
Via masking
C Shiva
C Shiva over 15 years ago
Hello Everyone,
    I'm facing an issue that if we put silktext on via hole, will it be properly printed or drilled out? As i saw in some boards silk text on via was drilled out and in some board it was properly printed.
    How can the silk text printed on board? I think it's after drilling and solder masking only. But the above issue is quite different.
    Kindly share your inputs.
Shiva.
  • zevmgross
    zevmgross over 15 years ago
    Hi  go to tools=>padstack=>modify design padstack chose via edit
    then change the slodermask top/bottom   to null then update
    this shoud fix  it
