  3. rezise drill legend
  • Views 13218
rezise drill legend
DRkidd22
DRkidd22 over 15 years ago
Hello all,
 I have a board all drawn up and I'm trying to figure out how would I rezise the drill legend.
I'm using Orcad PCB Editor
It's slighly bigger than the page size I'm using and I need it a little smaller.
 Any help will be appreciated.
  • oldmouldy
    oldmouldy over 15 years ago
    The Drill Legend is sized from the DLT, Drill Legend Template file, and the largest drill symbol. The DLT files are in the installation at share\pcb\text\nclegend use the documentation within the files as a guide to modifying them, you want to save your own modified version as a different DLT file. The Drill Symbol size can be changed from the Pad Designer, for libraries, or through Drill Customization within the design.
  • DRkidd22
    Ok, I have found the template files, now my question is, how do I edit the template files? I will be saving my own template.
  • DRkidd22
    nevermind, notepad does the trick
