  3. Capture CIS_Show Footprint
  • Replies 39
  • Subscribers 169
  • Views 37760
engineer123
engineer123 over 14 years ago
Can someone explain how I can set the correct paths for my symbol library so that I can view footprints inside capture. I have set the psmpath to the folder where my .psm and .dra files are located in the environment editor. However, when I select my part and choose show footprint I get an error stating allegro footprint not found in search path or something to that nature. However, if I use a symbol from the discrete capture library like a resistor and then select a footprint located in the cadence/..../share/pcb/pcb_lib/symbols folder it works. Are my libraries not set correctly even though I can place parts manually in pcb editor or is their something else I am missing. Thank you
  • PHMISTRY
    PHMISTRY over 12 years ago
    In this text document file all things was crete but foot print is missing.
    • footprint.txt
  • steve
    steve over 12 years ago
    It's very clear that you do not have a value set for the PCB Footprint. This is why you can't see it when you use RMB - Show Footprint and also why the netlister fails. Add a value for the PCB Footprint like SOIC8, 0603, QFP48 and make sure you have a PCB Footprint that matches that name and you should be good to go.
  • PHMISTRY
    Thanks Steve For your inforamation...
    Please Info us from where find out see proper value of the differ footprint. I am biggrner for this version ,i alredy work in its old version but i did not face this kind of problem.
    .brd file creat but still can't see the foot ptint in foot viewer and can't find the foot print at all running file.
    waiting for you ............
  • steve
    Find the part datasheet, locate the PCB Footprint, either find the footprint on line or create it in PCB Editor or PCB Libraries, save it and then use the footprint name as the property in Capture.
  • DaveCowl
    DaveCowl over 11 years ago
    I have a strange problem with Capture CIS regarding footprints.
    I can use the RMB->Show Footprint to view the Footprint of a part in my design, so it seems that the [Allegro Footprints] in the INI files is ok.
    However when I open CIS explorer, I cannot see any footprint when I select a part - just the Symbol. The Footprint window is empty.
    Is there a different place to link the footprint files into the CIS Explorer?
    Help appreciated.
    Cheers! Dave.
