  3. Routing differential pair with same length
  • Replies 8
  • Subscribers 169
  • Views 17670
TMCCANN
TMCCANN over 12 years ago
I am trying to route a differential pair, but I am having trouble making each trace the same length. Is there an easy way to do this in allegro?
  • TMCCANN
    Yes, that's what I thought. I will just have to rearrange the components or figure it out.
     Thanks!!
  • Robert Finley
    Robert Finley over 12 years ago
     What causes the requirement for both sides of a diff pair to be of equal length?  I've never had a respected SI engineer show concern about a 5mm length difference under 10gHz.
    Discussions of PCI-E 2.0 and 3.0 SI techniques focus on obtaining uniform dielectric properties along both nets.  No mention of matching lengths on the pair.
  • OLY29
    OLY29 over 12 years ago
    As you are routing the traces if you do a right mouse click you can select single mode and then only route one trace at a time to get them both the same length.
