  3. Placement Edit not working?
  • Replies 7
  • Subscribers 163
  • Views 20717
TH Designs
TH Designs over 12 years ago
 I have two sites where I use PCB Editor. One at a customer / employer and the other at my home office. Yesterday I took a file from the customer to my home office to continue working on it last night. When I opened the file to continue placing parts, placement edit would not work, meaning that I could not move any parts or text I had to use the "move" command to place the parts.
This is a small board with maybe 30 parts. normally I would select placement edit and have only "symbols" checked in the find filter. This would allow me to select and move any part on the board. It was not working this way. With placement edit selected as well as "symbol" when I selected a part, the part would highlight but I could not move it. The only way to move the part was to use the "move" command which is very time consuming.
This function worked just fine earlier in the week (and on several other boards) and it works just fine at the customers location. (same versions of Editor installed at both locations)
So the usual question......... What am I doing wrong?
Tom
  • oldmouldy
    oldmouldy over 12 years ago
    OK, last hope is that it's the single-click that's not enabled. Get into Placement Edit, right-click in the background canvas, Customize>Enable Single Click Execution, now the symbols in the canvas should get stuck to the mouse when you click on them.
  • TH Designs
     I'm baaack....... Couldn't log into the Forum for several days. Forum tech support couldn't figure out why............. For some reason I'm able to log in today. Time to play catch up.
    No earth shattering conclusions. After working on the board for a few days on a different computer, I took it back to my home office and I can now move and place parts like always. I didn't change any settings. The only thing I can point to would be a computer power down and power up cycle.
    Another anomaly solved, but not understood.............
    Thanks for the suggestions and assistance guys!
    Tom
